10 Replies Latest reply on May 27, 2015 12:48 PM by Daniel Sterchi
    Change link path
    sketcg
      I am looking for a way to change the file path of all my links in a document. I just need to remove part of the file path...
      If the original file path is
      /Volumes/My Passport/HiRes/990/9906.psd
      and I need to make it
      HiRes/990/990.psd
      Is there an action script or some hidden trick to rename all the links?
      I'm working on a mac in OS 10.9.5
      Thanks for any help!
        • 1. Re: Change link path
          Daniel Sterchi Adobe Community Professional
          Hi sketcg
          I have put together a few lines. Try them if the meet your needs.
          Would like to hear what you think.
          kind regards
          Daniel (from Switzerland)
           * written by Daniel Sterchi moonsoft.ch GmbH
          main();
          exit();
          function main() {
              if (app.documents.length > 0) {
                  const delimiter = "/";      // "/" for mac "\\" for windows at lieast I think so (have a mac)
                  // the active document
                  // get all the links of this document
                  var oldLinks = myDoc.links.everyItem().getElements();
                  // if there are any links
                  if (oldLinks.length > 0) {
                      // open a dialog
                      var newPath = new Folder(oldLinks[0].filePath).selectDlg("Choose a directory").fsName;
                      for (var i = 0; i < oldLinks.length; i++) {
                          // to get the filename of the Link.
                          // for windows you can use the folowing code
                          //      var myFileName = oldLinks[i].filePath;
                          //      myFileName = myFileName.substr(myFileName.lastIndexOf(delimiter) + 1, myFileName.length);
                          //      var newFile = File(newPath + delimiter + myFileName);
                          // This way you dont have to bother with HFS+ or UFS directory names with macs
                          var oldFile = File(oldLinks[i].filePath);
                          var newFile = File(newPath + delimiter + oldFile.name);
                          oldLinks[i].relink(newFile);
                  else alert("Information\nThis document has no links to pictures");
              else alert("Warning\nNo document open");
              alert("Information\nI have done my job, what about yours");
          • 2. Re: Change link path
            BSKTCreation Level 2
            Hi Daniel,
            On line 12 in your comments you mention Windows possibly being back-slashes, that is true for Windows explorer but for InDesign JavaScript it is forward-slashes.
            For example:
            "/v/Folder Name/File Name.indd"
            or
            "//server.address.com/Folder Name/File Name.jsx"
            Regards,
            Brett
            • 3. Re: Change link path
              Hi Brett
              Thats good news. I just don't have windows so I can't test it.
              Thanks for your input.
              • 4. Re: Change link path
                sketcg Level 1
                Daniel! Thank you so much for taking the time to look at this. I am a novice with the actionscript.
                I have taken your code and tried to use it but I get an error messageerror copy.jpg
                I will continue on trying to figure what I have wrong, but please let me know if you have a suggestion.
                Again Thanks!
                • 5. Re: Change link path
                  Hi sketcg
                  What the error message is telling you is, that there is a quotation mark missing at line 24 or above. And actually it is a JavaScript script ;-)
                  Can you provide us the changed script, then I can tell you what goes wrong.
                  kind regards
                  • 6. Re: Change link path
                    Vamitul Level 4
                    Regarding the Windows vs OSX delimiter:
                    Since the script uses ".fsName" you will have to worry about them because fsName will return the path in the standard platform format (eg. "c:\test\folder" or "/Users/Test/Folder").
                    My approach for these kinds of situations is to always use the Posix type of path for everything ("/c/test/folder"  works just fine on windows) and use fsName only for display purposes.
                    • 7. Re: Change link path
                      Hi Vamitul
                      The problem with the mac is that have HFS+ and UFS. I have to make sure that the old path and the new path are in the same format. Otherwise you have something like
                      newpath UFS: "/Users/…"
                      oldPath HFS+ "Macintosh HD:Users:USERNAME:directory
                      I just could do some tests on windows.
                      Here is what I get for Mac
                      and here what I get from Windows
                      Based on what I just saw i would change the script from:
                      to:
                      var newPath = new Folder(oldLinks[0].filePath).selectDlg("Choose a directory").fullName;
                      kind regards
                      • 8. Re: Change link path
                        Hi sketcg
                        This is a much smaller variation of the code which also works. It is also faster as the first one.
                        kind regards
                        main();
                        exit();
                        function main() {
                                    // open a dialog
                                    // traverse the array and relink
                                        var newFile = File(newPath + delimiter + oldLinks[i].name);
                                else alert("Information\nThis document has no links");
                        • 9. Re: Change link path
                          It looks like the end double quote got converted to a curly one (hence "unterminated string constant" because the starting quote is still okay). If that's the case, it is kind of weird because it is correct in Daniel's code.
                          • 10. Re: Change link path
                            Hi sketcg
                            Did you get it to work? Found the problem?
                            kind regards
