8 Replies Latest reply on Jan 13, 2007 11:16 PM by Newsgroup_User
    smooth edges
    Lauramodlin
      Hello. I am trying to create a design which is basically two different shaped triangles put together. I cannot figure out how to make the triangles other than create a rectangle and cutting it. But when I do that the edge I cut is jagged.
      Any ideas on how to smooth the edges or a better way to create oddly-shaped triangles?
      Laura
        • 1. Re: smooth edges
          Level 7
          I would use the pen tool to create the triangles. Make sure you have the
          'Edge' set to Anti-Alias. That applies to a modified rectangle as well.
          If you're not happy with the shape when completed it's very easy to modify
          using the 'Subselect Tool' (white arrow). Just click on one of the anchor
          points to select it and use the keyboard arrow keys to move it to where you
          want.
          You could also use the Polygon shape and set the number off sides to 3.
          Or the Smart Polygon, using the bottom left yellow adjustment to alter the
          number of sides.
          In all cases you want the Edge set to Anti-Alias or even Feather.
          Peter
          _______________________
          "Lauramodlin" <webforumsuser@macromedia.com> wrote in message
          news:envbj1$9vi$1@forums.macromedia.com...
          shaped
          other
          is
          | jagged.
          oddly-shaped
          | triangles?
          | Thanks,
          | Laura
          • 2. Re: smooth edges
            Level 7
            After re-reading your post, (it's early here) You don't need to cut your
            rectangle to create a triangle. Just ungoup the Rectangle (Modify + Ungroup)
            or (Ctrl+Shift+G) and select one of the corners with the subselect tool and
            delete it.
            Peter
            shaped
            other
            is
            | jagged.
            oddly-shaped
            | triangles?
            | Thanks,
            | Laura
            • 3. Re: smooth edges
              Lauramodlin Level 1
              Peter,
              Thanks for responding. I did the rectangle/ungroup/subselect and it created the shape I wanted (yay) but it still has the jagged edge (with anti-alias.) Any thoughts?
              Thanks again.
              Laura
              • 4. Re: smooth edges
                Level 7
                Hi, you could try various levels of Feathering, start low 1 or 2 and see if
                that helps?
                Peter
                news:envf0u$dd5$1@forums.macromedia.com...
                | Peter,
                created
                anti-alias.)
                | Any thoughts?
                | Thanks again.
                | Laura
                • 5. Re: smooth edges
                  Level 7
                  Laura,
                  Along with Peters suggestions, you can also select the Polygon tool and
                  select 3 sides from the Properties panel.
                  The Smart Polygon Tool is also fun to play with...
                  alex
                  > jagged.
                  > triangles?
                  > Thanks,
                  > Laura
                  • 6. Re: smooth edges
                    Level 7
                    Lauramodlin wrote:
                    > Peter,
                    Make the angles 45 degrees.
                    Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
                    http://www.projectseven.com
                    Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
                    CSS Newsgroup: news://forums.projectseven.com/css/
                    • 7. Re: smooth edges
                      Lauramodlin Level 1
                      Thanks. I am away from my computer today but will try these suggestions tonight and report back.
                      Laura
                      • 8. Re: smooth edges
                        Level 7
                        and make sure you're viewing at 100% not something like 97%... just in ca=
                        se
                        Alex Mari=F1o wrote:
                        > Laura,
                        >=20
                        > Along with Peters suggestions, you can also select the Polygon tool and=
                        =20
                        >=20
                        > alex
                        >=20
                        > Lauramodlin wrote:
                        >> Hello. I am trying to create a design which is basically two different=
                        =20
                        >> shaped triangles put together. I cannot figure out how to make the=20
                        >> triangles other than create a rectangle and cutting it. But when I do =
                        >> Any ideas on how to smooth the edges or a better way to create=20
                        >> Thanks,
                        >> Laura
