2 Replies Latest reply on May 25, 2015 7:30 AM by Bazsl
    Listener code to add layer mask fails...
    Bazsl Level 1
      Using Photoshop CC 2014 with all updates. The following script listener code was recorded when I clicked the Add Layer Mask button to add a mask to the active layer. When executeAction is called the script aborts with the following error dialog. Help! How can I add a layer mask to the active layer? Thanks.
      Error: General Photoshop error occurred. This functionality may not be available in this version of Photoshop. - The command "Make" is not currently available.
      function addLayerMask() {
        // Adds a layer mask to the active layer by clicking the
        // Add Layer Mask button.
        var idMk = charIDToTypeID( "Mk  " );
        var desc23 = new ActionDescriptor();
        var idNw = charIDToTypeID( "Nw  " );
        var idChnl = charIDToTypeID( "Chnl" );
        desc23.putClass( idNw, idChnl );
        var idAt = charIDToTypeID( "At  " );
        var ref20 = new ActionReference();
        var idMsk = charIDToTypeID( "Msk " );
        ref20.putEnumerated( idChnl, idChnl, idMsk );
        desc23.putReference( idAt, ref20 );
        var idUsng = charIDToTypeID( "Usng" );
        var idUsrM = charIDToTypeID( "UsrM" );
        var idRvlS = charIDToTypeID( "RvlS" );
        desc23.putEnumerated( idUsng, idUsrM, idRvlS );
        executeAction( idMk, desc23, DialogModes.NO );
        • 1. Re: Listener code to add layer mask fails...
          That code will work if you have an active selection.
            desc23.putEnumerated( idUsng, idUsrM, idRvlS );      //reveal selection
          app.activeDocument.selection.selectAll();
          addLayerMask();
          To add a layer mask without an active selection the is the scriptlistener code you would need
              var desc25 = new ActionDescriptor();
              desc25.putClass( idNw, idChnl );
                  var ref19 = new ActionReference();
                  ref19.putEnumerated( idChnl, idChnl, idMsk );
              desc25.putReference( idAt, ref19 );
              var idRvlA = charIDToTypeID( "RvlA" );
              desc25.putEnumerated( idUsng, idUsrM, idRvlA );  //reveal all
          executeAction( idMk, desc25, DialogModes.NO );
          addLayerMask()
          Then again there is hide all
              var desc33 = new ActionDescriptor();
              desc33.putClass( idNw, idChnl );
                  var ref27 = new ActionReference();
                  ref27.putEnumerated( idChnl, idChnl, idMsk );
              desc33.putReference( idAt, ref27 );
              var idHdAl = charIDToTypeID( "HdAl" );
              desc33.putEnumerated( idUsng, idUsrM, idHdAl );     //Hide all
          executeAction( idMk, desc33, DialogModes.NO );
          • 2. Re: Listener code to add layer mask fails...
            Bazsl Level 1
            Thanks for the very complete answer. My problem was that the selection was not being created, which I did not discover until I single stepped through the code and watched what was happening in Photoshop, and, of course, the error message provided no clue as to the real problem.
