2 Replies Latest reply on May 25, 2015 2:10 PM by macdaddy52
    export color problem
    macdaddy52
      I have LR CC 2015 and PS CC 2014 when I export my files into PS they get a yellow cast both are set to ProPhoto RGB 16 Bit does anyone know what is going on
        • 1. Re: export color problem
          D Fosse Adobe Community Professional & MVP
          That's a broken monitor profile. Recalibrate, or if you don't have a calibrator use sRGB until you do. It's not uncommon that different apps react differently to a bad profile.
          If you use a calibrator, make sure it produces v2, matrix/curve-based profiles, not v4 and/or LUT/table-based profiles. Either of the latter two can be problematic in some circumstances.
          Matching color settings in Lr/PS is not necessary. Each should display correctly regardless of profile.
          • 2. Re: export color problem
            macdaddy52 Level 1
            I really don't think that is the problem I installed LR 4 and it work perfectly this didn't happen until I installed the update to LR CC 2015. If I export it to Topaz Infusion first and open that file in Light room it shows the Edit Photo with Adobe Photoshop CC 2014 Box it opens in the correct color
