2 Replies Latest reply on May 25, 2015 10:19 PM by Monica Singh
    epub 線の指定
    アント93
      インデザインでepubを作成していますが、線が引けません。どうやったら引けるでしょうか?
        • 1. Re: epub 線の指定
          Steve Werner Adobe Community Professional & MVP
          I'm afraid you may not have told us enough information about your problem for us to help you.
          You can create lines in InDesign with the Line tool or the Pen tool. In the current version of InDesign CC 2014.2, both should be retained when exporting to EPUB.
          • 2. Re: epub 線の指定
            Monica Singh Adobe Employee
            Hi  アント,
            You may find discrepancy while exporting some compound paths to epub.
            Hence it is required to rasterise the same using Object-->Object export options-> Epub & HTML--> Preserve appearance from layout-->rasterise container/Content.
            This should help you. Your content may be turned into image but the appearance is retained.
            Monica Singh
            InDesign Team.
