8 Replies Latest reply on May 30, 2015 8:26 AM by Chuck Uebele
    Need help writing a script that batch proccesses images in a folder with different PS actions based on their name by referring to a CSV file.
    jackb58
      The short story...
      I need help writing a script that when ran will check a certain folder for new images then apply different actions to them in Photoshop based on their filename. i was thinking that using a CSV file (that we would create in excel) to refer to would be the best way to do this but I'm only a beginner at JavaScript and really have no clue how id refer to the csv file in JavaScript language. if someone could point me in the right direction that would be appreciated (I have looked all over and cant seem to find anything specific to my problem).
      The reason for this all is?
      I work for a canvas art/ portrait photography shop and we need to process many images a day using custom actions that move, resize and crop the image to fit print file dimensions. this currently needs someone to sit and set each action off to each image (The action names are also part of our Image codes in filename, this is how we would refer to them in the CSV file and this is how the worker currently knows which action to set off on which file)
      Sometimes there are exceptions to this and an image needs to have two actions set off at once (one to resize the other to change Hue). This adds complication to referring to CSV file as each image has multiple codes in its file name (one is product code for example and isn't used in this process) and so they aren't just named the same as the action that is ran off on them which would make the process easier and probably wouldn't require the CSV file.
      As I've said any help on the issue would be appreciated.
      Jack.
        • 1. Re: Need help writing a script that batch proccesses images in a folder with different PS actions based on their name by referring to a CSV file.
          Chuck Uebele Adobe Community Professional & MVP
          So would the file name be in the CSV file? or are just a list of actions in that file? What I'm trying to get as is do you need the CSV file. It sounds like you have your actions listed in the image's file name, so you just need to break down the file name and have the right action run from that. Using the "switch" function in javascript would take care of this.
          var actionToUse = 'some section of file name'
          switch(actionToUse){
               case: 'some setion of file name 1'
               //code to run action 1
               break;
               case: 'some setion of file name 2'
               //code to run action 2
               break;
          • 2. Re: Need help writing a script that batch proccesses images in a folder with different PS actions based on their name by referring to a CSV file.
            jackb58 Level 1
            Hello thank you for your time and response.
            It seems the CSV file might not be needed then based on your answer, you are correct in assuming that the name of the action is in the filename.
            The end result i am hoping to achieve is a script that (when opened) applies the correct actions to images in a drop-box style folder and then moves them to another folder after the action is ran off on them.
            The script needs to be able to distinguish which action to run on the image based on the last 6 characters of the filename (which is the name of the action to be ran off)
            Your suggestion of the "switch" function has progressed my understanding of how to do this but i still feel like i am missing certain elements of how to pull it all together into a working script
            I would like script to search the filenames of each image in the folder for the code that it would use to reference the action to be ran off on them.
            How would i accomplish this?
            • 3. Re: Need help writing a script that batch proccesses images in a folder with different PS actions based on their name by referring to a CSV file.
              Two ways you can do this. You can make a script that will work on a single image, then use the batch script or image processor to run a batch of files (you need to assign your script to an action for this to work). Or you can write a script that will take a folder full of images and process them all.
              To not have to use the batch script you need to put into your script the code that will get all files and tell if they are files or folders, and the right type of files. You can look at scripts like image processor to see how this is done on both Win and Mac systems. Lets just say you know all the files are ones you want in a particular folder. You would use something like:
              var myFolder = new Folder('/c/my folder path/');
              var searchMask = '*.???';//use whatever search is best for you. if all the files are NEF, use that.
              selectedFiles = myFolder.getFiles(searchMask);
              You can then write a function to check the files for the proper type, as mentioned above. Then you loop through the files and find out which ones get what processing:
              for(var i=0;i<selectedFiles.length;i++){
              var fileName= selectedFiles[i].name.split('.')[0];//assumes that you only have one dot in the file name for the extension.
              var suffix = fileName..substring(docName.length - 6, docName.length).toUpperCase();//turn it to upper case to they're all the same.
              switch(suffix){
                   case: 'action1'
                   //your code here
                   break;
                   case: 'action2'
                   //your code here
                   break;
              • 4. Re: Need help writing a script that batch proccesses images in a folder with different PS actions based on their name by referring to a CSV file.
                jackb58 Level 1
                I'm looking to be able to do the second method you have mentioned. Thank you for your time, but being an absolute newbie to JavaScript I'm still stuck on this. If i break down the process that i'm following and give you all the information I hope you will be able to point out where i am going wrong here.
                I currently have a folder named 'Test' on my desktop, I'm using this as a dummy test before moving the script to practical use.
                This folder contains the aforementioned Javascript and two other folders, one named source (where the images start out), the other named end (the destination for the images after processing).
                In the 'source' folder there are four images, the file names are as follows
                0001-blue
                0001-green
                0001-red
                0001-yellow
                I am hoping to apply an action called 'blue' to the image with blue in the file name and then have it moved to the 'end' folder and then do the same to the other images
                On to the script...
                I found a tool which converts photoshop actions into javascript which i have used to extract the code from my test actions. I then put the code into my script and declared these actions as functions like so
                1. function Blue()
                2. {
                3. \\ photoshop action code
                4. }
                When i try to use what you wrote above by putting these functions inbetween the case: and break; in the switch function it comes up as an error saying
                ": does not have a value"
                • 5. Re: Need help writing a script that batch proccesses images in a folder with different PS actions based on their name by referring to a CSV file.
                  In line 12, you have a double dot after filename. It should be only one dot.
                  • 6. Re: Need help writing a script that batch proccesses images in a folder with different PS actions based on their name by referring to a CSV file.
                    Also looking at the script, in line 11 I had a split that was defined as split('.'), You have it as split(5.10). That won't work. What the split does is splits a string into an array at whatever is defined in the parenthesis. Mine is to separate the file name from the extension at the dot. Looking at your file name structure, you could also use a split rather than the substring as is shown in line 12. the split could be defined as split('-')[1]. This will break the file name up at the hyphen. If there is only one hyphen in the name, then you can use the 1 to define what part of the break to use. Otherwise you need to write some code to figure out what the last section of the break would be.
                    • 7. Re: Need help writing a script that batch proccesses images in a folder with different PS actions based on their name by referring to a CSV file.
                      jackb58 Level 1
                      I have followed up what you said and made those changes along with some others but there still seems to be complications, I'm now encountering another problem with the part of the script that cuts up the filename for the case to read. when ran it says 'undefined is not an object'
                      i have posted the full code below, spent so long on this one job its coming to the point where you need to decide whether to move onto something else but i feel like im so close to completion
                      if you could so kindly point out my mistake it would be greatly appreciated.
                      The error im discussing refers to line 1720 and 1722
                      #target photoshop
                      //functions start
                      function Blue ()
                      {if(typeof jamEngine!=='object') {var jamEngine={};(function() {var that;jamEngine.meaningfulIds=false;jamEngine.parseFriendly=false;var conflictingStringIdStrs={"'Algn'":["align","alignment"],"'AntA'":["antiAlias","antiAliasedPICTAcquire"],"'BckL'":["backgroundLayer","backgroundLevel"],"'BlcG'":["blackGenerationType","blackGenerationCurve"],"'BlcL'":["blackLevel","blackLimit"],"'Blks'":["blacks","blocks"],"'BlrM'":["blurMethod","blurMore"],"'BrgC'":["brightnessEvent","brightnessContrast"],"'BrsD'":["brushDetail","brushesDefine"],"'Brsh'":["brush","brushes"],"'Clcl'":["calculation","calculations"],"'ClrP'":["colorPalette","coloredPencil"],"'Cnst'":["constant","constrain"],"'CntC'":["centerCropMarks","conteCrayon"],"'Cntr'":["center","contrast"],"'CrtD'":["createDroplet","createDuplicate"],"'CstP'":["customPalette","customPhosphors"],"'Cstm'":["custom","customPattern"],"'Drkn'":["darken","darkness"],"'Dstr'":["distort","distortion","distribute","distribution"],"'Dstt'":["desaturate","destWhiteMax"],"'FlIn'":["fileInfo","fillInverse"],"'Gd  '":["good","guide"],"'GnrP'":["generalPreferences","generalPrefs","preferencesClass"],"'GrSt'":["grainStippled","graySetup"],"'Grdn'":["gradientClassEvent","gridMinor"],"'Grn '":["grain","green"],"'Grns'":["graininess","greens"],"'HstP'":["historyPreferences","historyPrefs"],"'HstS'":["historyState","historyStateSourceType"],"'ImgP'":["imageCachePreferences","imagePoint"],"'In  '":["in","stampIn"],"'IntW'":["interfaceWhite","intersectWith"],"'Intr'":["interfaceIconFrameDimmed","interlace","interpolation","intersect"],"'JPEG'":["JPEG","JPEGFormat"],"'LghD'":["lightDirection","lightDirectional"],"'LghO'":["lightOmni","lightenOnly"],"'LghS'":["lightSource","lightSpot"],"'Lns '":["lens","lines"],"'Mgnt'":["magenta","magentas"],"'MrgL'":["mergeLayers","mergedLayers"],"'Mxm '":["maximum","maximumQuality"],"'NTSC'":["NTSC","NTSCColors"],"'NmbL'":["numberOfLayers","numberOfLevels"],"'PlgP'":["pluginPicker","pluginPrefs"],"'Pncl'":["pencilEraser","pencilWidth"],"'Pnt '":["paint","point"],"'Prsp'":["perspective","perspectiveIndex"],"'PrvM'":["previewMacThumbnail","previewMagenta"],"'Pstr'":["posterization","posterize"],"'RGBS'":["RGBSetup","RGBSetupSource"],"'Rds '":["radius","reds"],"'ScrD'":["scratchDisks","screenDot"],"'ShdI'":["shadingIntensity","shadowIntensity"],"'ShpC'":["shapeCurveType","shapingCurve"],"'ShrE'":["sharpenEdges","shearEd"],"'Shrp'":["sharpen","sharpness"],"'SplC'":["splitChannels","supplementalCategories"],"'Spot'":["spot","spotColor"],"'SprS'":["separationSetup","sprayedStrokes"],"'StrL'":["strokeLength","strokeLocation"],"'Strt'":["saturation","start"],"'TEXT'":["char","textType"],"'TIFF'":["TIFF","TIFFFormat"],"'TglO'":["toggleOptionsPalette","toggleOthers"],"'TrnG'":["transparencyGamutPreferences","transparencyGrid","transparencyGridSize"],"'TrnS'":["transferSpec","transparencyShape","transparencyStop"],"'Trns'":["transparency","transparent"],"'TxtC'":["textClickPoint","textureCoverage"],"'TxtF'":["textureFile","textureFill"],"'UsrM'":["userMaskEnabled","userMaskOptions"],"'c@#^'":["inherits","pInherits"],"'comp'":["comp","sInt64"],"'doub'":["floatType","IEEE64BitFloatingPoint","longFloat"],"'long'":["integer","longInteger","sInt32"],"'magn'":["magnitude","uInt32"],"'null'":["null","target"],"'shor'":["sInt16","sMInt","shortInteger"],"'sing'":["IEEE32BitFloatingPoint","sMFloat","shortFloat"]};jamEngine.getConflictingStringIdStrs=function(charIdStr) {return conflictingStringIdStrs[charIdStr]||null;};jamEngine.uniIdStrToId=function(uniIdStr) {var id=0;if(typeof uniIdStr==='string') {if((uniIdStr.length===(1+4+1))&&(uniIdStr.charAt(0)==="'")&&(uniIdStr.charAt(5)==="'")) {id=app.charIDToTypeID(uniIdStr.substring(1,5));} else {id=app.stringIDToTypeID(uniIdStr);}} return id;};var smallestHashValue=app.charIDToTypeID("    ");jamEngine.idToUniIdStrs=function(id) {var charIdStr="";var stringIdStr=app.typeIDToStringID(id);if(id>=smallestHashValue) {charIdStr="'"+app.typeIDToCharID(id)+"'";if(stringIdStr!=="") {if(charIdStr in conflictingStringIdStrs) {stringIdStr=conflictingStringIdStrs[charIdStr];}}} return[charIdStr,stringIdStr];};jamEngine.equivalentUniIdStrs=function(uniIdStr1,uniIdStr2) {return this.uniIdStrToId(uniIdStr1)===this.uniIdStrToId(uniIdStr2);};function putInReference(ref,containers) {if(containers.constructor===Array) {var count=containers.length;for(var i=0;i<count;i++) {var container=that.parseCompact(containers[i]);var desiredClassId=that.uniIdStrToId(container[0]);var typedValue=that.parseCompact(container[1]);var form=typedValue[0];var value=typedValue[1];switch(form) {case"<class>":ref.putClass(desiredClassId);break;case"<enumerated>":var enumerated=that.parseCompact(value);ref.putEnumerated(desiredClassId,that.uniIdStrToId(enumerated[0]),that.uniIdStrToId(enumerated[1]));break;case"<identifier>":ref.putIdentifier(desiredClassId,value);break;case"<index>":ref.putIndex(desiredClassId,value);break;case"<name>":ref.putName(desiredClassId,value);break;case"<offset>":ref.putOffset(desiredClassId,value);break;case"<property>":ref.putProperty(desiredClassId,that.uniIdStrToId(value));break;default:throw new Error("[jamEngine putInReference] Unknown reference form: "+form);break;}}} else {throw new Error("[jamEngine putInReference] JavaScript array expected");}} function putInList(list,items) {if(items.constructor===Array) {var count=items.length;for(var i=0;i<count;i++) {var item=that.parseCompact(items[i]);var type=item[0];var value=item[1];switch(type) {case"<boolean>":list.putBoolean(value);break;case"<class>":list.putClass(that.uniIdStrToId(value));break;case"<data>":list.putData(value);break;case"<double>":list.putDouble(value);break;case"<enumerated>":var enumerated=that.parseCompact(value);list.putEnumerated(that.uniIdStrToId(enumerated[0]),that.uniIdStrToId(enumerated[1]));break;case"<integer>":list.putInteger(value);break;case"<largeInteger>":list.putLargeInteger(value);break;case"<list>":var actionList=new ActionList();putInList(actionList,value);list.putList(actionList);break;case"<object>":var object=that.parseCompact(value);if(object[1]) {var actionDescriptor=new ActionDescriptor();putInDescriptor(actionDescriptor,object[1]);list.putObject(that.uniIdStrToId(object[0]),actionDescriptor);} else {list.putClass(that.uniIdStrToId(object[0]));} break;case"<path>":var fileRef=new File(value);list.putPath(fileRef);break;case"<reference>":var actionReference=new ActionReference();putInReference(actionReference,value);list.putReference(actionReference);break;case"<string>":list.putString(value);break;case"<unitDouble>":var unitDouble=that.parseCompact(value);list.putUnitDouble(that.uniIdStrToId(unitDouble[0]),unitDouble[1]);break;default:throw new Error("[jamEngine putInList] Unknown list type: "+type);break;}}} else {throw new Error("[jamEngine putInList] JavaScript array expected");}} function putInDescriptor(desc,members) {if(members.constructor===Object) {for(var key in members) {if(members.hasOwnProperty(key)) {var keyID=that.uniIdStrToId(key);var member=that.parseCompact(members[key]);var type=member[0];var value=member[1];switch(type) {case"<boolean>":desc.putBoolean(keyID,value);break;case"<class>":desc.putClass(keyID,that.uniIdStrToId(value));break;case"<data>":desc.putData(keyID,value);break;case"<double>":desc.putDouble(keyID,value);break;case"<enumerated>":var enumerated=that.parseCompact(value);desc.putEnumerated(keyID,that.uniIdStrToId(enumerated[0]),that.uniIdStrToId(enumerated[1]));break;case"<integer>":desc.putInteger(keyID,value);break;case"<largeInteger>":desc.putLargeInteger(keyID,value);break;case"<list>":var actionList=new ActionList();putInList(actionList,value);desc.putList(keyID,actionList);break;case"<object>":var object=that.parseCompact(value);if(object[1]) {var actionDescriptor=new ActionDescriptor();putInDescriptor(actionDescriptor,object[1]);desc.putObject(keyID,that.uniIdStrToId(object[0]),actionDescriptor);} else {desc.putClass(keyID,that.uniIdStrToId(object[0]));} break;case"<path>":var fileRef=new File(value);desc.putPath(keyID,fileRef);break;case"<reference>":var actionReference=new ActionReference();putInReference(actionReference,value);desc.putReference(keyID,actionReference);break;case"<string>":desc.putString(keyID,value);break;case"<unitDouble>":var unitDouble=that.parseCompact(value);desc.putUnitDouble(keyID,that.uniIdStrToId(unitDouble[0]),unitDouble[1]);break;default:throw new Error("[jamEngine putInDescriptor] Unknown descriptor type: "+type);break;}}}} else {throw new Error("[jamEngine putInDescriptor] JavaScript object expected");}} var contextRules={"'Algn'":{"<classKey>":{"bevelEmboss":"align","frameFX":"align","gradientFill":"align","gradientLayer":"align","patternFill":"align","patternLayer":"align"},"<event>":"align","<key>":"alignment"},"'AntA'":{"<class>":"antiAliasedPICTAcquire","<key>":"antiAlias"},"'BckL'":{"<class>":"backgroundLayer","<key>":"backgroundLevel"},"'BlcG'":{"<enumType>":"blackGenerationType","<key>":"blackGenerationCurve"},"'BlcL'":{"<classKey>":{"'GEfc'":"blackLevel","CMYKSetup":"blackLimit"},"<eventKey>":{"reticulation":"blackLevel"}},"'Blks'":{"<typeValue>":{"colors":"blacks","extrudeType":"blocks"}},"'BlrM'":{"<enumType>":"blurMethod","<event>":"blurMore","<key>":"blurMethod"},"'BrgC'":{"<class>":"brightnessContrast","<event>":"brightnessContrast"},"'BrsD'":{"<enumValue>":"brushesDefine","<key>":"brushDetail"},"'Brsh'":{"<class>":"brush","<key>":"brushes"},"'Clcl'":{"<class>":"calculation","<enumValue>":"calculations","<key>":"calculation"},"'ClrP'":{"<typeValue>":{"'GEft'":"coloredPencil"},"<enumType>":"colorPalette","<event>":"coloredPencil"},"'Cnst'":{"<classKey>":{"channelMatrix":"constant"},"<unknown>":"constrain"},"'CntC'":{"<typeValue>":{"'GEft'":"conteCrayon"},"<event>":"conteCrayon","<key>":"centerCropMarks"},"'Cntr'":{"<classKey>":{"'GEfc'":"contrast","brightnessContrast":"contrast","document":"center","polygon":"center","quadrilateral":"center"},"<eventKey>":{"adaptCorrect":"contrast","brightnessEvent":"contrast","grain":"contrast","halftoneScreen":"contrast","sumie":"contrast","tornEdges":"contrast","waterPaper":"contrast"},"<enumValue>":"center"},"'CrtD'":{"<enumValue>":"createDuplicate","<event>":"createDroplet"},"'CstP'":{"<class>":"customPhosphors","<key>":"customPalette"},"'Cstm'":{"<enumValue>":"customPattern","<event>":"custom","<key>":"custom"},"'Drkn'":{"<enumValue>":"darken","<key>":"darkness"},"'Dstr'":{"<classKey>":{"'GEfc'":"distortion"},"<eventKey>":{"glass":"distortion","addNoise":"distribution"},"<enumType>":"distribution","<enumValue>":"distort","<event>":"distribute"},"'Dstt'":{"<enumValue>":"desaturate","<event>":"desaturate","<key>":"destWhiteMax"},"'FlIn'":{"<typeValue>":{"fillColor":"fillInverse","menuItemType":"fileInfo"},"<class>":"fileInfo","<key>":"fileInfo"},"'Gd  '":{"<class>":"guide","<enumValue>":"good"},"'GnrP'":{"<class>":"preferencesClass","<enumValue>":"generalPreferences","<key>":"generalPrefs"},"'GrSt'":{"<class>":"graySetup","<enumValue>":"grainStippled","<key>":"graySetup"},"'Grdn'":{"<class>":"gradientClassEvent","<event>":"gradientClassEvent","<key>":"gridMinor"},"'Grn '":{"<typeValue>":{"'GEft'":"grain"},"<classKey>":{"'GEfc'":"grain","RGBColor":"green","blackAndWhite":"green","channelMatrix":"green","channelMixer":"green"},"<eventKey>":{"blackAndWhite":"green","channelMixer":"green","filmGrain":"grain"},"<enumValue>":"green","<event>":"grain"},"'Grns'":{"<enumValue>":"greens","<key>":"graininess"},"'HstP'":{"<enumValue>":"historyPreferences","<key>":"historyPrefs"},"'HstS'":{"<class>":"historyState","<enumType>":"historyStateSourceType"},"'ImgP'":{"<class>":"imagePoint","<enumValue>":"imageCachePreferences"},"'In  '":{"<enumValue>":"stampIn","<key>":"in"},"'IntW'":{"<event>":"intersectWith","<key>":"interfaceWhite"},"'Intr'":{"<typeValue>":{"shapeOperation":"intersect"},"<classKey>":{"GIFFormat":"interlace","SaveForWeb":"interlace","application":"interfaceIconFrameDimmed","computedBrush":"interpolation","gradientClassEvent":"interpolation","photoshopEPSFormat":"interpolation"},"<eventKey>":{"convertMode":"interpolation","imageSize":"interpolation","transform":"interpolation"},"<event>":"intersect"},"'JPEG'":{"<class>":"JPEGFormat","<enumValue>":"JPEG"},"'LghD'":{"<enumType>":"lightDirection","<enumValue>":"lightDirectional","<key>":"lightDirection"},"'LghO'":{"<typeValue>":{"diffuseMode":"lightenOnly","lightType":"lightOmni"}},"'LghS'":{"<class>":"lightSource","<enumValue>":"lightSpot","<key>":"lightSource"},"'Lns '":{"<enumType>":"lens","<enumValue>":"lines","<key>":"lens"},"'Mgnt'":{"<typeValue>":{"channel":"magenta","colors":"magentas","guideGridColor":"magenta"},"<key>":"magenta"},"'MrgL'":{"<enumValue>":"mergedLayers","<event>":"mergeLayers"},"'Mxm '":{"<enumValue>":"maximumQuality","<event>":"maximum","<key>":"maximum"},"'NTSC'":{"<enumValue>":"NTSC","<event>":"NTSCColors"},"'NmbL'":{"<classKey>":{"'GEfc'":"numberOfLevels","document":"numberOfLayers"},"<eventKey>":{"cutout":"numberOfLevels"}},"'PlgP'":{"<class>":"pluginPrefs","<enumValue>":"pluginPicker","<key>":"pluginPrefs"},"'Pncl'":{"<enumValue>":"pencilEraser","<key>":"pencilWidth"},"'Pnt '":{"<typeValue>":{"textType":"point"},"<class>":"point","<event>":"paint"},"'Prsp'":{"<enumValue>":"perspective","<key>":"perspectiveIndex"},"'PrvM'":{"<enumValue>":"previewMagenta","<key>":"previewMacThumbnail"},"'Pstr'":{"<class>":"posterize","<event>":"posterize","<key>":"posterization"},"'RGBS'":{"<enumType>":"RGBSetupSource","<key>":"RGBSetup"},"'Rds '":{"<enumValue>":"reds","<key>":"radius"},"'ScrD'":{"<enumValue>":"screenDot","<key>":"scratchDisks"},"'ShdI'":{"<classKey>":{"'GEfc'":"shadowIntensity"},"<eventKey>":{"watercolor":"shadowIntensity"},"<unknown>":"shadingIntensity"},"'ShpC'":{"<classKey>":{"application":"shapingCurve"},"<class>":"shapingCurve","<key>":"shapeCurveType"},"'ShrE'":{"<event>":"sharpenEdges","<key>":"shearEd"},"'Shrp'":{"<event>":"sharpen","<key>":"sharpness"},"'SplC'":{"<event>":"splitChannels","<key>":"supplementalCategories"},"'Spot'":{"<enumValue>":"spotColor","<key>":"spot"},"'SprS'":{"<typeValue>":{"'GEft'":"sprayedStrokes"},"<enumValue>":"separationSetup","<event>":"sprayedStrokes"},"'StrL'":{"<enumType>":"strokeLocation","<key>":"strokeLength"},"'Strt'":{"<classKey>":{"currentToolOptions":"saturation","fileNamingRules":"start","HSBColorClass":"saturation","hueSatAdjustment":"saturation","hueSatAdjustmentV2":"saturation","lineClass":"start","range":"start","vibrance":"saturation"},"<eventKey>":{"replaceColor":"saturation","variations":"saturation","vibrance":"saturation"},"<enumValue>":"saturation"},"'TEXT'":{"<enumType>":"textType","<key>":"textType"},"'TIFF'":{"<class>":"TIFFFormat","<enumValue>":"TIFF"},"'TglO'":{"<enumValue>":"toggleOptionsPalette","<key>":"toggleOthers"},"'TrnG'":{"<classKey>":{"application":"transparencyGrid","transparencyPrefs":"transparencyGridSize"},"<enumType>":"transparencyGridSize","<enumValue>":"transparencyGamutPreferences"},"'TrnS'":{"<classKey>":{"bevelEmboss":"transparencyShape","dropShadow":"transparencyShape","innerGlow":"transparencyShape","innerShadow":"transparencyShape","outerGlow":"transparencyShape"},"<class>":"transparencyStop","<unknown>":"transferSpec"},"'Trns'":{"<enumValue>":"transparent","<key>":"transparency"},"'TxtC'":{"<classKey>":{"'GEfc'":"textureCoverage","textLayer":"textClickPoint"},"<eventKey>":{"underpainting":"textureCoverage"}},"'TxtF'":{"<event>":"textureFill","<key>":"textureFile"},"'UsrM'":{"<enumType>":"userMaskOptions","<key>":"userMaskEnabled"},"'null'":{"<class>":"null","<enumValue>":"null","<event>":"null","<key>":"target"}};function getFromId(context,parentContext) {var uniIdStr;var kind=context[0];var id=context[1];if(id<smallestHashValue) {uniIdStr=app.typeIDToStringID(id);} else {uniIdStr="'"+app.typeIDToCharID(id)+"'";if(that.meaningfulIds) {if(uniIdStr in contextRules) {function resolveIdStr(candidates) {var idStr="";for(var parentString in candidates) {if(candidates.hasOwnProperty(parentString)) {if(parentContext[1]===that.uniIdStrToId(parentString)) {idStr=candidates[parentString];break;}}} return idStr;} var resolvedIdStr="";var rule=contextRules[uniIdStr];if(parentContext) {switch(kind) {case"<key>":if((parentContext[0]==="<class>")&&("<classKey>"in rule)) {resolvedIdStr=resolveIdStr(rule["<classKey>"]);} else if((parentContext[0]==="<event>")&&("<eventKey>"in rule)) {resolvedIdStr=resolveIdStr(rule["<eventKey>"]);} break;case"<enumValue>":if((parentContext[0]==="<enumType>")&&("<typeValue>"in rule)) {resolvedIdStr=resolveIdStr(rule["<typeValue>"]);} break;}} if(resolvedIdStr!=="") {uniIdStr=resolvedIdStr;} else if(kind in rule) {uniIdStr=rule[kind];}} else {var stringIDStr=app.typeIDToStringID(id);if(stringIDStr!=="") {uniIdStr=stringIDStr;}}}} return uniIdStr;} var incompatiblePlatformPath="";var getEventId=app.stringIDToTypeID("get");var targetKeyId=app.stringIDToTypeID("target");var propertyClassId=app.stringIDToTypeID("property");function getFromReference(ref) {var propertyId=0;var arr=[];do {try{var desiredClassId=ref.getDesiredClass();}catch(e){break;} if(propertyId!==0) {var propertyCompact=that.buildCompact("<property>",getFromId(["<key>",propertyId],["<class>",desiredClassId]));arr.push(that.buildCompact(getFromId(["<class>",propertyClassId]),propertyCompact));propertyId=0;} var desiredCompact;var aFormID=ref.getForm();switch(aFormID) {case ReferenceFormType.CLASSTYPE:desiredCompact=that.buildCompact("<class>",null);break;case ReferenceFormType.ENUMERATED:var enumTypeContext=["<enumType>",ref.getEnumeratedType()];var enumValueContext=["<enumValue>",ref.getEnumeratedValue()];desiredCompact=that.buildCompact("<enumerated>",that.buildCompact(getFromId(enumTypeContext),getFromId(enumValueContext,enumTypeContext)));break;case ReferenceFormType.IDENTIFIER:desiredCompact=that.buildCompact("<identifier>",ref.getIdentifier());break;case ReferenceFormType.INDEX:desiredCompact=that.buildCompact("<index>",ref.getIndex());break;case ReferenceFormType.NAME:desiredCompact=that.buildCompact("<name>",ref.getName());break;case ReferenceFormType.OFFSET:desiredCompact=that.buildCompact("<offset>",ref.getOffset());break;case ReferenceFormType.PROPERTY:if(desiredClassId===propertyClassId) {propertyId=ref.getProperty();} else {desiredCompact=that.buildCompact("<property>",getFromId(["<key>",ref.getProperty()],["<class>",desiredClassId]));} break;default:throw new Error("[jamEngine getFromReference] Unknown reference form type: "+aFormID);break;} if(desiredClassId!==propertyClassId) {arr.push(that.buildCompact(getFromId(["<class>",desiredClassId]),desiredCompact));} ref=ref.getContainer();} while(ref);return arr;} function getFromList(list) {var arr=[];var itemCount=list.count;for(var itemIndex=0;itemIndex<itemCount;itemIndex++) {var itemCompact;var typeID;try{typeID=list.getType(itemIndex);}catch(e){continue;} switch(typeID) {case DescValueType.BOOLEANTYPE:itemCompact=that.buildCompact("<boolean>",list.getBoolean(itemIndex));break;case DescValueType.CLASSTYPE:itemCompact=that.buildCompact("<class>",getFromId(["<class>",list.getClass(itemIndex)]));break;case DescValueType.DOUBLETYPE:itemCompact=that.buildCompact("<double>",list.getDouble(itemIndex));break;case DescValueType.ENUMERATEDTYPE:var enumTypeContext=["<enumType>",list.getEnumerationType(itemIndex)];var enumValueContext=["<enumValue>",list.getEnumerationValue(itemIndex)];itemCompact=that.buildCompact("<enumerated>",that.buildCompact(getFromId(enumTypeContext),getFromId(enumValueContext,enumTypeContext)));break;case DescValueType.INTEGERTYPE:itemCompact=that.buildCompact("<integer>",list.getInteger(itemIndex));break;case DescValueType.LISTTYPE:itemCompact=that.buildCompact("<list>",getFromList(list.getList(itemIndex)));break;case DescValueType.OBJECTTYPE:var objectTypeContext=["<class>",list.getObjectType(itemIndex)];var objectValue=list.getObjectValue(itemIndex);itemCompact=that.buildCompact("<object>",that.buildCompact(getFromId(objectTypeContext),getFromDescriptor(objectValue,objectTypeContext)));break;case DescValueType.ALIASTYPE:try {var fileRef=list.getPath(itemIndex);itemCompact=that.buildCompact("<path>",fileRef.fsName);} catch(e) {itemCompact=that.buildCompact("<path>",incompatiblePlatformPath);} break;case DescValueType.REFERENCETYPE:itemCompact=that.buildCompact("<reference>",getFromReference(list.getReference(itemIndex)));break;case DescValueType.STRINGTYPE:itemCompact=that.buildCompact("<string>",list.getString(itemIndex));break;case DescValueType.UNITDOUBLE:var unitTypeContext=["<unit>",list.getUnitDoubleType(itemIndex)];var doubleValue=list.getUnitDoubleValue(itemIndex);itemCompact=that.buildCompact("<unitDouble>",that.buildCompact(getFromId(unitTypeContext),doubleValue));break;default:var isRawType;var isLargeIntegerType;try{isRawType=(typeID===DescValueType.RAWTYPE);}catch(e){} try{isLargeIntegerType=(typeID===DescValueType.LARGEINTEGERTYPE);}catch(e){} if(isRawType) {itemCompact=that.buildCompact("<data>",list.getData(itemIndex));} else if(isLargeIntegerType) {itemCompact=that.buildCompact("<largeInteger>",list.getLargeInteger(itemIndex));} else {throw new Error("[jamEngine getFromList] Unknown descriptor value type: "+typeID);} break;} arr[itemIndex]=itemCompact;} return arr;} function getFromDescriptor(desc,parentContext) {if(desc) {var obj={};var keyCount;try{keyCount=desc.count;}catch(e){return null;} for(var keyIndex=0;keyIndex<keyCount;keyIndex++) {var keyID=desc.getKey(keyIndex);var keyString=getFromId(["<key>",keyID],parentContext);var keyCompact;var typeID;try{typeID=desc.getType(keyID);}catch(e){continue;} switch(typeID) {case DescValueType.BOOLEANTYPE:keyCompact=that.buildCompact("<boolean>",desc.getBoolean(keyID));break;case DescValueType.CLASSTYPE:keyCompact=that.buildCompact("<class>",getFromId(["<class>",desc.getClass(keyID)]));break;case DescValueType.DOUBLETYPE:keyCompact=that.buildCompact("<double>",desc.getDouble(keyID));break;case DescValueType.ENUMERATEDTYPE:var enumTypeContext=["<enumType>",desc.getEnumerationType(keyID)];var enumValueContext=["<enumValue>",desc.getEnumerationValue(keyID)];keyCompact=that.buildCompact("<enumerated>",that.buildCompact(getFromId(enumTypeContext),getFromId(enumValueContext,enumTypeContext)));break;case DescValueType.INTEGERTYPE:keyCompact=that.buildCompact("<integer>",desc.getInteger(keyID));break;case DescValueType.LISTTYPE:keyCompact=that.buildCompact("<list>",getFromList(desc.getList(keyID)));break;case DescValueType.OBJECTTYPE:var objectTypeContext=["<class>",desc.getObjectType(keyID)];var objectValue=desc.getObjectValue(keyID);keyCompact=that.buildCompact("<object>",that.buildCompact(getFromId(objectTypeContext),getFromDescriptor(objectValue,objectTypeContext)));break;case DescValueType.ALIASTYPE:try {var fileRef=desc.getPath(keyID);keyCompact=that.buildCompact("<path>",fileRef.fsName);} catch(e) {keyCompact=that.buildCompact("<path>",incompatiblePlatformPath);} break;case DescValueType.REFERENCETYPE:keyCompact=that.buildCompact("<reference>",getFromReference(desc.getReference(keyID)));break;case DescValueType.STRINGTYPE:keyCompact=that.buildCompact("<string>",desc.getString(keyID));break;case DescValueType.UNITDOUBLE:var unitTypeContext=["<unit>",desc.getUnitDoubleType(keyID)];var doubleValue=desc.getUnitDoubleValue(keyID);keyCompact=that.buildCompact("<unitDouble>",that.buildCompact(getFromId(unitTypeContext),doubleValue));break;default:var isRawType;var isLargeIntegerType;try{isRawType=(typeID===DescValueType.RAWTYPE);}catch(e){} try{isLargeIntegerType=(typeID===DescValueType.LARGEINTEGERTYPE);}catch(e){} if(isRawType) {keyCompact=that.buildCompact("<data>",desc.getData(keyID));} else if(isLargeIntegerType) {keyCompact=that.buildCompact("<largeInteger>",desc.getLargeInteger(keyID));} else {throw new Error("[jamEngine getFromDescriptor] Unknown descriptor value type: "+typeID);} break;} obj[keyString]=keyCompact;} return obj;} else {return null;}} jamEngine.jsonToActionDescriptor=function(descriptorObj) {that=this;var actionDescriptor;if(descriptorObj) {actionDescriptor=new ActionDescriptor();putInDescriptor(actionDescriptor,descriptorObj);} return actionDescriptor;};jamEngine.jsonToActionReference=function(referenceArr) {that=this;var actionReference;if(referenceArr) {actionReference=new ActionReference();putInReference(actionReference,referenceArr);} return actionReference;};jamEngine.eventIdAndActionDescriptorToJson=function(eventId,actionDescriptor) {that=this;var eventIdContext=["<event>",eventId];return{"<event>":getFromId(eventIdContext),"<descriptor>":getFromDescriptor(actionDescriptor,eventIdContext)};};jamEngine.classIdAndActionDescriptorToJson=function(classId,actionDescriptor) {that=this;var classIdContext=["<class>",classId];return{"<class>":getFromId(classIdContext),"<descriptor>":getFromDescriptor(actionDescriptor,classIdContext)};};jamEngine.actionReferenceToJson=function(actionReference) {that=this;return getFromReference(actionReference);};function getReferenceClassId(ref) {classId=0;do {try{var desiredClassId=ref.getDesiredClass();}catch(e){break;} if(desiredClassId!==propertyClassId) {classId=desiredClassId;break;} ref=ref.getContainer();} while(ref);return classId;} jamEngine.jsonPlay=function(eventUniIdStr,descriptorObj,displayDialogs) {var eventId=this.uniIdStrToId(eventUniIdStr);var desc=this.jsonToActionDescriptor(descriptorObj);var parentContext;if(eventId===getEventId) {var ref=desc.getReference(targetKeyId);parentContext=["<class>",getReferenceClassId(ref)];} else {parentContext=["<event>",eventId];} return getFromDescriptor(app.executeAction(eventId,desc,displayDialogs),parentContext);};jamEngine.jsonGet=function(referenceArr) {var ref=this.jsonToActionReference(referenceArr);return getFromDescriptor(app.executeActionGet(ref),["<class>",getReferenceClassId(ref)]);};jamEngine.normalizeJsonItem=function(item,options) {function normalizeItem(item) {var explicit=that.parseCompact(item);var type=explicit[0];var value=explicit[1];var normalizedValue;switch(type) {case"<boolean>":case"<data>":case"<double>":case"<identifier>":case"<index>":case"<integer>":case"<largeInteger>":case"<name>":case"<offset>":case"<path>":case"<string>":normalizedValue=value;break;case"<class>":normalizedValue=value&&getFromId(["<class>",that.uniIdStrToId(value)]);break;case"<enumerated>":var enumerated=that.parseCompact(value);var enumTypeContext=["<enumType>",that.uniIdStrToId(enumerated[0])];var enumValueContext=["<enumValue>",that.uniIdStrToId(enumerated[1])];normalizedValue=that.buildCompact(getFromId(enumTypeContext),getFromId(enumValueContext,enumTypeContext));break;case"<list>":normalizedValue=[];for(var i=0;i<value.length;i++) {normalizedValue.push(normalizeItem(value[i]));} break;case"<object>":var object=that.parseCompact(value);var objectClassContext=["<class>",that.uniIdStrToId(object[0])];var objectDescriptor=object[1];var normalizedDescriptor;if(objectDescriptor===null) {normalizedDescriptor=null;} else {normalizedDescriptor={};for(var key in objectDescriptor) {if(objectDescriptor.hasOwnProperty(key)) {var objectKeyContext=["<key>",that.uniIdStrToId(key)];normalizedDescriptor[getFromId(objectKeyContext,objectClassContext)]=normalizeItem(objectDescriptor[key]);}}} normalizedValue=that.buildCompact(getFromId(objectClassContext),normalizedDescriptor);break;case"<property>":normalizedValue=getFromId(["<key>",that.uniIdStrToId(value)]);break;case"<reference>":normalizedValue=[];for(var i=0;i<value.length;i++) {var container=that.parseCompact(value[i]);normalizedValue.push(that.buildCompact(getFromId(["<class>",that.uniIdStrToId(container[0])]),normalizeItem(container[1])));} break;case"<unitDouble>":var unitDouble=that.parseCompact(value);var unitTypeContext=["<unit>",that.uniIdStrToId(unitDouble[0])];normalizedValue=that.buildCompact(getFromId(unitTypeContext),unitDouble[1]);break;default:throw new Error("[jamEngine.normalizeJsonItem] Unknown item type: "+type);break;} return that.buildCompact(type,normalizedValue);} that=this;var saveMeaningfulIds=this.meaningfulIds;var saveParseFriendly=this.parseFriendly;if(options&&(options.constructor===Object)) {if(typeof options.meaningfulIds!=='undefined') {this.meaningfulIds=options.meaningfulIds;} if(typeof options.parseFriendly!=='undefined') {this.parseFriendly=options.parseFriendly;}} var normalizedItem=normalizeItem(item);this.meaningfulIds=saveMeaningfulIds;this.parseFriendly=saveParseFriendly;return normalizedItem;};function simplifyRef(ref) {var simplifiedRef=[];for(var i=0;i<ref.length;i++) {var element=ref[i];var simplifiedElement={};var desiredClass=element[0];var form=element[1][0];var value=element[1][1];switch(form) {case"<class>":case"<identifier>":case"<index>":case"<name>":case"<offset>":case"<property":simplifiedElement[desiredClass]=value;break;case"<enumerated>":simplifiedElement[desiredClass]=value[1];break;default:throw new Error("[jamEngine simplifyRef] Unexpected element form: "+form);break;} simplifiedRef.push(simplifiedElement);} return simplifiedRef;} function simplifyItem(item,hook) {var simplifiedItem;var type=item[0];var value=item[1];switch(type) {case"<boolean>":case"<class>":case"<data>":case"<double>":case"<integer>":case"<largeInteger>":case"<path>":case"<string>":simplifiedItem=value;break;case"<list>":simplifiedItem=simplifyList(value,hook);break;case"<enumerated>":case"<unitDouble>":simplifiedItem=value[1];break;case"<object>":simplifiedItem=simplifyDesc(value[1],hook);break;case"<reference>":simplifiedItem=simplifyRef(value);break;default:throw new Error("[jamEngine simplifyItem] Unexpected item type: "+type);break;} return simplifiedItem;} function simplifyList(list,hook) {var simplifiedList=[];for(var i=0;i<list.length;i++) {simplifiedList.push(simplifyItem(list[i],hook));} return simplifiedList;} function simplifyDesc(desc,hook) {var getDefaultValue=function(desc,key){return simplifyItem(desc[key],hook);};var simplifiedDesc={};for(var key in desc) {if(desc.hasOwnProperty(key)) {var value=undefined;if(typeof hook==='function') {value=hook(desc,key,getDefaultValue);} if(typeof value==='undefined') {value=simplifyItem(desc[key],hook);} simplifiedDesc[key]=value;}} return simplifiedDesc;} jamEngine.simplifyObject=function(object,hookFunction) {return simplifyDesc((this.normalizeJsonItem(object,{meaningfulIds:true,parseFriendly:true}))[1][1],hookFunction);};jamEngine.simplifyList=function(list,hookFunction) {return simplifyList((this.normalizeJsonItem(list,{meaningfulIds:true,parseFriendly:true}))[1],hookFunction);};jamEngine.parseCompact=function(compact) {var result=[];if(compact.constructor===Object) {var keys=[];for(var k in compact) {if(compact.hasOwnProperty(k)) {keys.push(k);}} if(keys.length===1) {result[0]=keys[0];result[1]=compact[keys[0]];} else {throw new Error("[jamEngine.parseCompact] Syntax error: "+compact.toSource());}} else if(compact.constructor===Array) {if(compact.length===2) {result[0]=compact[0];result[1]=compact[1];} else {throw new Error("[jamEngine.parseCompact] Syntax error: "+compact.toSource());}} else {throw new Error("[jamEngine.parseCompact] JavaScript object or array expected");} return result;};jamEngine.compactToExplicit=function(compact,typeKey,valueKey) {var explicit={};var typeValue=this.parseCompact(compact);explicit[typeKey||"<type>"]=typeValue[0];explicit[valueKey||"<value>"]=typeValue[1];return explicit;};jamEngine.buildCompact=function(type,value) {var compact;if(typeof type==='string') {if(this.parseFriendly) {compact=[type,value];} else {compact={};compact[type]=value;}} else {throw new Error("[jamEngine.buildCompact] String expected");} return compact;};jamEngine.explicitToCompact=function(explicit,typeKey,valueKey) {var compact;if(explicit.constructor===Object) {compact=this.buildCompact(explicit[typeKey||"<type>"],explicit[valueKey||"<value>"]);} else {throw new Error("[jamEngine.explicitToCompact] JavaScript object expected");} return compact;};for(var charIdStr in conflictingStringIdStrs) {if(conflictingStringIdStrs.hasOwnProperty(charIdStr)) {var stringIdStrs=conflictingStringIdStrs[charIdStr];for(var index=stringIdStrs.length-1;index>=0;index--) {var stringIdStr=stringIdStrs[index];if(!(app.charIDToTypeID(charIdStr.substring(1,5))===app.stringIDToTypeID(stringIdStr))) {stringIdStrs.splice(index,1);}} if(stringIdStrs.length<2) {delete conflictingStringIdStrs[charIdStr];}}} for(var charIdStr in contextRules) {if(contextRules.hasOwnProperty(charIdStr)) {if(charIdStr in conflictingStringIdStrs) {var rule=contextRules[charIdStr];for(var kind in rule) {if(rule.hasOwnProperty(kind)) {switch(kind) {case"<class>":case"<event>":case"<enumType>":case"<enumValue>":case"<key>":case"<unknown>":if(app.charIDToTypeID(charIdStr.substring(1,5))!=app.stringIDToTypeID(rule[kind])) {throw new Error("[jamEngine] "+"\""+charIdStr+"\" and \""+rule[kind]+"\" are not equivalent ID strings");} break;case"<classKey>":case"<eventKey>":case"<typeValue>":for(var parent in rule[kind]) {if(rule[kind].hasOwnProperty(parent)) {if(app.charIDToTypeID(charIdStr.substring(1,5))!=app.stringIDToTypeID(rule[kind][parent])) {throw new Error("[jamEngine] "+"\""+charIdStr+"\" and \""+rule[kind][parent]+"\" are not equivalent ID strings");}}} break;}}}} else {delete contextRules[charIdStr];}}}}());}
                      jamEngine.meaningfulIds = true;
                      jamEngine.parseFriendly = true;
                      // Action “blue”
                      try
                          // Make
                          if (true)
                              jamEngine.jsonPlay
                                  "make",
                                      "target":
                                          "<reference>",
                                                  "layer",
                                                      "<class>",
                                                      null
                                  DialogModes.NO
                          // Set
                          if (true)
                              jamEngine.jsonPlay
                                  "set",
                                      "target":
                                          "<reference>",
                                                  "property",
                                                      "<property>",
                                                      "gridMinor"
                                                  "application",
                                                      "<enumerated>",
                                                          "ordinal",
                                                          "targetEnum"
                                      "to":
                                          "<path>",
                                          "/Applications/Adobe Photoshop CS6/Presets/Gradients/Simple.grd"
                                  DialogModes.NO
                          // Gradient
                          if (true)
                              jamEngine.jsonPlay
                                      "from":
                                          "<object>",
                                              "point",
                                                  "horizontal":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          -5.76
                                                  "vertical":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          -4.32
                                      "to":
                                          "<object>",
                                              "point",
                                                  "horizontal":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          137.04
                                                  "vertical":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          90.48
                                      "type":
                                          "<enumerated>",
                                              "gradientType",
                                              "linear"
                                      "dither":
                                          "<boolean>",
                                          true
                                      "useMask":
                                          "<boolean>",
                                          true
                                      "gradient":
                                          "<object>",
                                                  "name":
                                                      "<string>",
                                                      "$$$/Presets/Gradients/Simple_grd/Blue=Blue"
                                                  "gradientForm":
                                                      "<enumerated>",
                                                          "gradientForm",
                                                          "customStops"
                                                  "interpolation":
                                                      "<double>",
                                                      4096
                                                  "colors":
                                                      "<list>",
                                                              "<object>",
        "colorStop",
        "color":
        "<object>",
        "CMYKColorClass",
        "cyan":
        "<double>",
        0
        "magenta":
        "<double>",
        0
        "yellowColor":
        "<double>",
        0
        "black":
        "<double>",
        0
        "type":
        "<enumerated>",
        "colorStopType",
        "userStop"
        "location":
        "<integer>",
        0
        "midpoint":
        "<integer>",
        50
                                                              "<object>",
        "colorStop",
        "color":
        "<object>",
        "CMYKColorClass",
        "cyan":
        "<double>",
        95
        "magenta":
        "<double>",
        51
        "yellowColor":
        "<double>",
        3
        "black":
        "<double>",
        0
        "type":
        "<enumerated>",
        "colorStopType",
        "userStop"
        "location":
        "<integer>",
        4096
        "midpoint":
        "<integer>",
        50
                                                  "transparency":
                                                      "<list>",
                                                              "<object>",
        "transparencyStop",
        "opacity":
        "<unitDouble>",
        "percentUnit",
        100
        "location":
        "<integer>",
        0
        "midpoint":
        "<integer>",
        50
                                                              "<object>",
        "transparencyStop",
        "opacity":
        "<unitDouble>",
        "percentUnit",
        100
        "location":
        "<integer>",
        4096
        "midpoint":
        "<integer>",
        50
                                  DialogModes.NO
                          // Set
                          if (true)
                              jamEngine.jsonPlay
                                  "set",
                                      "target":
                                          "<reference>",
                                                  "layer",
                                                      "<enumerated>",
                                                          "ordinal",
                                                          "targetEnum"
                                      "to":
                                          "<object>",
                                              "layer",
                                                  "opacity":
                                                      "<unitDouble>",
                                                          "percentUnit",
                                                          53
                                  DialogModes.NO
                      catch (e)
                          if (e.number !== 8007)  // Not a user cancel error
                              try
                                  jamEngine.jsonPlay
                                      "stop",
                                          "message":
                                              "<string>",
                                              e.message.replace (/^.*\n- /, "")
                                      DialogModes.ALL
                              catch (e)
                      function Red ()
                      // Action “red”
                      try
                          // Make
                          if (true)
                              jamEngine.jsonPlay
                                  "make",
                                      "target":
                                          "<reference>",
                                                  "layer",
                                                      "<class>",
                                                      null
                                  DialogModes.NO
                          // Set
                          if (true)
                              jamEngine.jsonPlay
                                  "set",
                                      "target":
                                          "<reference>",
                                                  "property",
                                                      "<property>",
                                                      "gridMinor"
                                                  "application",
                                                      "<enumerated>",
                                                          "ordinal",
                                                          "targetEnum"
                                      "to":
                                          "<path>",
                                  DialogModes.NO
                          // Gradient
                          if (true)
                              jamEngine.jsonPlay
                                      "from":
                                          "<object>",
                                              "point",
                                                  "horizontal":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          -4.8
                                                  "vertical":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          -3.12
                                      "to":
                                          "<object>",
                                              "point",
                                                  "horizontal":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          111.12
                                                  "vertical":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          73.2
                                      "type":
                                          "<enumerated>",
                                              "gradientType",
                                              "linear"
                                      "dither":
                                          "<boolean>",
                                          true
                                      "useMask":
                                          "<boolean>",
                                          true
                                      "gradient":
                                          "<object>",
                                                  "name":
                                                      "<string>",
                                                      "$$$/Presets/Gradients/Simple_grd/Red=Red"
                                                  "gradientForm":
                                                      "<enumerated>",
                                                          "gradientForm",
                                                          "customStops"
                                                  "interpolation":
                                                      "<double>",
                                                      4096
                                                  "colors":
                                                      "<list>",
                                                              "<object>",
        "colorStop",
        "color":
        "<object>",
        "CMYKColorClass",
        "cyan":
        "<double>",
        0
        "magenta":
        "<double>",
        0
        "yellowColor":
        "<double>",
        0
        "black":
        "<double>",
        0
        "type":
        "<enumerated>",
        "colorStopType",
        "userStop"
        "location":
        "<integer>",
        0
        "midpoint":
        "<integer>",
        50
                                                              "<object>",
        "colorStop",
        "color":
        "<object>",
        "CMYKColorClass",
        "cyan":
        "<double>",
        1
        "magenta":
        "<double>",
        96
        "yellowColor":
        "<double>",
        91
        "black":
        "<double>",
        0
        "type":
        "<enumerated>",
        "colorStopType",
        "userStop"
        "location":
        "<integer>",
        4096
        "midpoint":
        "<integer>",
        50
                                                  "transparency":
                                                      "<list>",
                                                              "<object>",
        "transparencyStop",
        "opacity":
        "<unitDouble>",
        "percentUnit",
        100
        "location":
        "<integer>",
        0
        "midpoint":
        "<integer>",
        50
                                                              "<object>",
        "transparencyStop",
        "opacity":
        "<unitDouble>",
        "percentUnit",
        100
        "location":
        "<integer>",
        4096
        "midpoint":
        "<integer>",
        50
                                  DialogModes.NO
                          // Set
                          if (true)
                              jamEngine.jsonPlay
                                  "set",
                                      "target":
                                          "<reference>",
                                                  "layer",
                                                      "<enumerated>",
                                                          "ordinal",
                                                          "targetEnum"
                                      "to":
                                          "<object>",
                                              "layer",
                                                  "opacity":
                                                      "<unitDouble>",
                                                          "percentUnit",
                                                          60
                                  DialogModes.NO
                      catch (e)
                              try
                                  jamEngine.jsonPlay
                                      "stop",
                                          "message":
                                              "<string>",
                                      DialogModes.ALL
                              catch (e)
                      function Yellow ()
                      // Action “yellow”
                      try
                          // Make
                          if (true)
                              jamEngine.jsonPlay
                                  "make",
                                      "target":
                                          "<reference>",
                                                  "layer",
                                                      "<class>",
                                                      null
                                  DialogModes.NO
                          // Set
                          if (true)
                              jamEngine.jsonPlay
                                  "set",
                                      "target":
                                          "<reference>",
                                                  "property",
                                                      "<property>",
                                                      "gridMinor"
                                                  "application",
                                                      "<enumerated>",
                                                          "ordinal",
                                                          "targetEnum"
                                      "to":
                                          "<path>",
                                  DialogModes.NO
                          // Gradient
                          if (true)
                              jamEngine.jsonPlay
                                      "from":
                                          "<object>",
                                              "point",
                                                  "horizontal":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          -6.48
                                                  "vertical":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          -4.32
                                      "to":
                                          "<object>",
                                              "point",
                                                  "horizontal":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          123.12
                                                  "vertical":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          79.92
                                      "type":
                                          "<enumerated>",
                                              "gradientType",
                                              "linear"
                                      "dither":
                                          "<boolean>",
                                          true
                                      "useMask":
                                          "<boolean>",
                                          true
                                      "gradient":
                                          "<object>",
                                                  "name":
                                                      "<string>",
                                                      "$$$/Presets/Gradients/Simple_grd/Yellow=Yellow"
                                                  "gradientForm":
                                                      "<enumerated>",
                                                          "gradientForm",
                                                          "customStops"
                                                  "interpolation":
                                                      "<double>",
                                                      4096
                                                  "colors":
                                                      "<list>",
                                                              "<object>",
        "colorStop",
        "color":
        "<object>",
        "CMYKColorClass",
        "cyan":
        "<double>",
        0
        "magenta":
        "<double>",
        0
        "yellowColor":
        "<double>",
        0
        "black":
        "<double>",
        0
        "type":
        "<enumerated>",
        "colorStopType",
        "userStop"
        "location":
        "<integer>",
        0
        "midpoint":
        "<integer>",
        50
                                                              "<object>",
        "colorStop",
        "color":
        "<object>",
        "CMYKColorClass",
        "cyan":
        "<double>",
        0
        "magenta":
        "<double>",
        0
        "yellowColor":
        "<double>",
        95
        "black":
        "<double>",
        0
        "type":
        "<enumerated>",
        "colorStopType",
        "userStop"
        "location":
        "<integer>",
        4096
        "midpoint":
        "<integer>",
        50
                                                  "transparency":
                                                      "<list>",
                                                              "<object>",
        "transparencyStop",
        "opacity":
        "<unitDouble>",
        "percentUnit",
        100
        "location":
        "<integer>",
        0
        "midpoint":
        "<integer>",
        50
                                                              "<object>",
        "transparencyStop",
        "opacity":
        "<unitDouble>",
        "percentUnit",
        100
        "location":
        "<integer>",
        4096
        "midpoint":
        "<integer>",
        50
                                  DialogModes.NO
                          // Set
                          if (true)
                              jamEngine.jsonPlay
                                  "set",
                                      "target":
                                          "<reference>",
                                                  "layer",
                                                      "<enumerated>",
                                                          "ordinal",
                                                          "targetEnum"
                                      "to":
                                          "<object>",
                                              "layer",
                                                  "opacity":
                                                      "<unitDouble>",
                                                          "percentUnit",
                                                          54
                                  DialogModes.NO
                      catch (e)
                              try
                                  jamEngine.jsonPlay
                                      "stop",
                                          "message":
                                              "<string>",
                                      DialogModes.ALL
                              catch (e)
                      function Green ()
                      // Action “green”
                      try
                          // Make
                          if (true)
                              jamEngine.jsonPlay
                                  "make",
                                      "target":
                                          "<reference>",
                                                  "layer",
                                                      "<class>",
                                                      null
                                  DialogModes.NO
                          // Set
                          if (true)
                              jamEngine.jsonPlay
                                  "set",
                                      "target":
                                          "<reference>",
                                                  "property",
                                                      "<property>",
                                                      "gridMinor"
                                                  "application",
                                                      "<enumerated>",
                                                          "ordinal",
                                                          "targetEnum"
                                      "to":
                                          "<path>",
                                  DialogModes.NO
                          // Gradient
                          if (true)
                              jamEngine.jsonPlay
                                      "from":
                                          "<object>",
                                              "point",
                                                  "horizontal":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          -5.76
                                                  "vertical":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          -2.16
                                      "to":
                                          "<object>",
                                              "point",
                                                  "horizontal":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          128.64
                                                  "vertical":
                                                      "<unitDouble>",
                                                          "distanceUnit",
                                                          85.44
                                      "type":
                                          "<enumerated>",
                                              "gradientType",
                                              "linear"
                                      "dither":
                                          "<boolean>",
                                          true
                                      "useMask":
                                          "<boolean>",
                                          true
                                      "gradient":
                                          "<object>",
                                                  "name":
                                                      "<string>",
                                                      "$$$/Presets/Gradients/Simple_grd/LimeGreen=Lime Green"
                                                  "gradientForm":
                                                      "<enumerated>",
                                                          "gradientForm",
                                                          "customStops"
                                                  "interpolation":
                                                      "<double>",
                                                      4096
                                                  "colors":
                                                      "<list>",
                                                              "<object>",
        "colorStop",
        "color":
        "<object>",
        "CMYKColorClass",
        "cyan":
        "<double>",
        0
        "magenta":
        "<double>",
        0
        "yellowColor":
        "<double>",
        0
        "black":
        "<double>",
        0
        "type":
        "<enumerated>",
        "colorStopType",
        "userStop"
        "location":
        "<integer>",
        0
        "midpoint":
        "<integer>",
        50
                                                              "<object>",
        "colorStop",
        "color":
        "<object>",
        "CMYKColorClass",
        "cyan":
        "<double>",
        45
        "magenta":
        "<double>",
        3
        "yellowColor":
        "<double>",
        74
        "black":
        "<double>",
        0
        "type":
        "<enumerated>",
        "colorStopType",
        "userStop"
        "location":
        "<integer>",
        4096
        "midpoint":
        "<integer>",
        50
                                                  "transparency":
                                                      "<list>",
                                                              "<object>",
        "transparencyStop",
        "opacity":
        "<unitDouble>",
        "percentUnit",
        100
        "location":
        "<integer>",
        0
        "midpoint":
        "<integer>",
        50
                                                              "<object>",
        "transparencyStop",
        "opacity":
        "<unitDouble>",
        "percentUnit",
        100
        "location":
        "<integer>",
        4096
        "midpoint":
        "<integer>",
        50
                                  DialogModes.NO
                          // Set
                          if (true)
                              jamEngine.jsonPlay
                                  "set",
                                      "target":
                                          "<reference>",
                                                  "layer",
                                                      "<enumerated>",
                                                          "ordinal",
                                                          "targetEnum"
                                      "to":
                                          "<object>",
                                              "layer",
                                                  "opacity":
                                                      "<unitDouble>",
                                                          "percentUnit",
                                                          65
                                  DialogModes.NO
                      catch (e)
                              try
                                  jamEngine.jsonPlay
                                      "stop",
                                          "message":
                                              "<string>",
                                      DialogModes.ALL
                              catch (e)
                      //functions end
                      //user input to select processing folder
                      var fileName
                      var suffix
                      var searchMask = '*.jpg'; //to use JPEG's
                      var sourceFolder = Folder.selectDialog("Select the source folder");
                      var sourceFiles = sourceFolder.getFiles();
                       if (sourceFolder != null)
                           var sourceFiles = sourceFolder.getFiles(searchMask);
                           var are = "Are these the files you were looking for?";
                           alert(are)
                           var fileList = confirm(sourceFiles)
                           if (fileList === true)
                               var yes = "Success!";
                               alert(yes);
                           else
                               var no = "Oh no!";
                               alert(no);
                      //end of folder selection
                      for(var i=0;i<sourceFiles.length;i++)
                      var fileName = sourceFiles.get[i].name.split('.')[0];
                      var suffix = fileName[0].name.split('-')[1];
                      switch(suffix)
                           case 'blue':
                           Blue ();
                           break;
                           case 'red':
                           Red ();
                           break;
                           case 'yellow':
                           Yellow ();
                           break;
                           case 'green':
                           Green ();
                           break;
                      var outputFolder = Folder.selectDialog("Select the output folder");
                      • 8. Re: Need help writing a script that batch proccesses images in a folder with different PS actions based on their name by referring to a CSV file.
                        Line 1699 should read:
                        There might be other things, but start with that. you might have something in that folder that's not a file.
                        Also change 1723 to:
                        var suffix = fileName.name.split('-')[1];
