2 Replies Latest reply on Jan 11, 2007 4:17 PM by cratica
    Text Field Background transparent?
    cratica Level 1
      I am using a text field member to display file names that the user selects. I want this text field member to be semi-transparent or even 100% transparent but can't seem to find a way to do this. When I adjust the ink blend value for this sprite, the text inside the field changes, but the field itself does not.
      Is there any way to make a text field background transparent?
      Thanks!
        • 1. Re: Text Field Background transparent?
          Level 7
          A couple of notes:
          The Direct to stage option for text members provides faster scrolling
          but prevents ink effects from working.
          The scrollbar seems to always render direct to stage flashing on
          separately when a new frame is accessed, using the custom scrollbar (
          with text member mode set to fixed size) behavior from the library
          palette with custom art allows blend settings to work on nthe scroll bar.
          • 2. Re: Text Field Background transparent?
            cratica Level 1
            Thanks JB.
            Bottom line is I don't believe the field member's background can be modified. There is no provision for changing the direct to stage function, therefore background transparencies are disabled.
            What I did was used a text field instead and now I have the desired effect.
