3 Replies Latest reply on May 26, 2015 8:49 AM by Mylenium
    Working with Corrupted Frames
    barker85 Level 1
      Hi there,
      I am working with some corrupted footage and am having to remove the corrupted frames (about a dozen or so in a 10 second clip for example), frame by frame.
      Generally the corruptions are only a frame at a time and removing them, then changing the length of the previous frame in Premiere to 50% is producing quite seamless results. However, this is not always the case, particularly when the interview subject is moving a lot or in instances of two frames being corrupted in tandem.
      I am wondering if there are any effects/techniques in After Effects that may provide a more seamless fix for this (i.e. for a more fluid transition between frames)?
      Any thoughts are hugely appreciated.
      Many thanks...
