1 Reply Latest reply on Jun 3, 2015 3:37 AM by hissizadam
    Deploy test app on iOS simulator
    joanp48483775
      Hi there,
      I'm trying to run a simple test app on a iOS simulator but I'm getting this error:
      Error occurred while packaging the application:
      [Fatal Error] :1:1: Content is not allowed in prolog.
      java.io.IOException: PLIST generation failed due to SAX error:org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
        at com.adobe.air.Plist.newFromString(Plist.java:351)
        at com.adobe.air.Plist.newFromFile(Plist.java:325)
        at com.adobe.air.ipa.IPAOutputStream.setSDKVersion(IPAOutputStream.java:1070)
        at com.adobe.air.ipa.IPAOutputStream.setPlatformSDKLocation(IPAOutputStream.java:971)
        at com.adobe.air.ipa.IPAPackager.setDeviceSDKDirectory(IPAPackager.java:187)
        at com.adobe.air.ADT.parseFileAndPathArguments(ADT.java:1423)
        at com.adobe.air.ADT.parseDescriptorAndFileset(ADT.java:1474)
        at com.adobe.air.ADT.parseInput(ADT.java:929)
        at com.adobe.air.ADT.parsePackage(ADT.java:672)
        at com.adobe.air.ADT.parseArgsAndGo(ADT.java:570)
        at com.adobe.air.ADT.run(ADT.java:419)
        at com.adobe.air.ADT.main(ADT.java:469)
      Exception in thread "main" java.lang.Error: Unable to find llvm JNI lib in:
      /Applications/Adobe Flash Builder 4.7/eclipse/plugins/com.adobe.flash.compiler_4.7.0.349722/AIRSDK/lib/adt.jar/Darwin
      /Applications/Adobe Flash Builder 4.7/eclipse/plugins/com.adobe.flash.compiler_4.7.0.349722/AIRSDK/lib/aot/lib/x64
        at adobe.abc.LLVMEmitter.loadJNI(LLVMEmitter.java:582)
        at adobe.abc.LLVMEmitter.<clinit>(LLVMEmitter.java:596)
        at com.adobe.air.ipa.AOTCompiler.generateExtensionsGlue(AOTCompiler.java:419)
        at com.adobe.air.ipa.AOTCompiler.generateMachineBinaries(AOTCompiler.java:1790)
        at com.adobe.air.ipa.IPAOutputStream.createIosBinary(IPAOutputStream.java:378)
        at com.adobe.air.ipa.IPAOutputStream.finalizeSig(IPAOutputStream.java:743)
        at com.adobe.air.ApplicationPackager.createPackage(ApplicationPackager.java:91)
        at com.adobe.air.ipa.IPAPackager.createPackage(IPAPackager.java:245)
        at com.adobe.air.ADT.parseArgsAndGo(ADT.java:571)
      I've google it and I was not able to fix it.
      Steps to reproduce:
      1. Create an ActionScriptMobileProject
      2. Configure it to run on iOS simulator
      3. run it without any change in the code.
