3 Replies Latest reply on May 27, 2015 1:35 AM by Rebecca Lai
    Failed: Script to save ditamap to FM with ditaval file
    Rebecca Lai
      Hi FM scripting Gurus,
      I'm stuck in the following issue and need help:
      I'm trying to write a script to save ditamaps to composite FM files with ditaval file specified. I use the document property Constants.FS_DitavalFile (=linux.txt) to specify the ditaval file. Unfortunately, it seems that the script does not execute the SaveCompoFm function. If I remove the Constants.FS_DitavalFile property from the function, the script runs properly. I've no idea what the problem is. The following is the SaveCompoFm function. Is there anything wrong with the code? Thanks a lot for your help!
      function SaveCompoFm(file,saveName,ditaval)
          saveProp = GetSaveDefaultParams()
          i = GetPropIndex(saveProp, Constants.FS_FileType)
          saveProp[i].propVal.ival =Constants.FV_SaveFmtCompositeDoc
          i = GetPropIndex(saveProp, Constants.FS_DitavalFile)
          saveProp[i].propVal.ival =ditaval
          retParm = new PropVals()
          CompoFm=file.Save(saveName,saveProp,retParm);
          return CompoFm;
