0 Replies Latest reply on Jan 9, 2007 10:38 AM by katzdi88
    Flexunit and Flex 2.0.1
    katzdi88
      I'm having a problem migrating from Flex 2 to Flex 2.0.1.
      Specifically, I get the following error from the Flex Builder compiler
      when attempting to do a clean build. Does anyone know a solution to
      the following problem? (Running Flex Builder 2.0.1 Eclipse plug-in on
      Windows.)
      !ENTRY com.adobe.flexbuilder.project 4 43 2007-01-09 18:14:06.31
      !MESSAGE Uncaught exception in compiler
      !STACK 0
      unable to load SWC flexunit.swc
      at flex2.compiler.swc.SwcCache.getSwc(SwcCache.java:230)
      at flex2.compiler.swc.SwcCache.getSwcs(SwcCache.java:151)
      at flex2.compiler.swc.SwcCache.getSwcGroup(SwcCache.java:78)
      at flex2.compiler.swc.SwcCache.getSwcGroup(SwcCache.java:67)
      at flex2.compiler.CompilerSwcContext.load(CompilerSwcContext.java:52)
      at flex2.tools.oem.Application.recompile(Application.java:723)
      at flex2.tools.oem.Application.compile(Application.java:530)
      at flex2.tools.flexbuilder.BuilderApplication.compile(BuilderApplication.java:224)
      at com.adobe.flexbuilder.project.compiler.internal.ASApplicationBuilder$MyBuilder.mybuild(Un known
      Source)
      at com.adobe.flexbuilder.project.compiler.internal.ASApplicationBuilder.build(Unknown
      Source)
      at com.adobe.flexbuilder.project.compiler.internal.ASBuilder.build(Unknown
      Source)
      at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.buildApplication(U nknown
      Source)
      at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(Unknown
      Source)
      at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:593)
      at org.eclipse.core.internal.runtime.InternalPlatform.run(InternalPlatform.java:1044)
      at org.eclipse.core.runtime.Platform.run(Platform.java:783)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:168)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:202)
      at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:231)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:234)
      at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:253)
      at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:282)
      at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:211)
      at org.eclipse.ui.actions.GlobalBuildAction$1.run(GlobalBuildAction.java:182)
      at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
      Thanks in advance for your help.
      Best,
      David
