We have developed e-learning module with Captivate v.8.
It contains question bank with 70 True/False radio button questions.
Module contains 1 quiz with 30 random questions from this question bank.
At the end of quiz there is summary page to display quiz score and number of correctly answered questions.
We don't use playbar for this module.
After publishing module, we faced following problems:
Module published in HTML format
Module published in Flash format
Does anyone has any idea what causes this problem?
Did you delete embedded objects on question slides or master slides? Can
you check value of some quizzing system variables by inserting them in a
text container on the first question slide and time them for rest of
project to find out where it is going awry?
On Question slides I left Submit button, Clear button and behind it Next button (it's for reviewing).
On Result slide I have Review and Next butttons and it displays Correct Questions and Accuracy.
I'll try to insert variables and check what is going on with HTML output. Update - I've done it - $$cpQuizInfoPointsscored$$ and $$cpQuizInfoTotalCorrectAnswers$$ shows 0 all the time, correct answers aren't counted.
You did delete Continue in Results slide, not a good idea because that is
the trigger for the Actions from Quiz settings. Only buttons that can be
turned off by a checkbox (like Back, Clear) should be controlled.
However it is very worrying that the sys vars didn't update after each
question as is normally the case. Sure you did not delete other elements on
question slides:.title?
Sorry, with Next button I meant Continue button in Result slide, wich I have. I use custome Image buttons, therefore didn't see original names.
I checked again and yes, you are right, I have deleted Title Placeholder. Can it cause this behavior?
As I mentioned in a previous answer, deleting embedded objects can lead to
weird results, question slides have very strict rules. Something has
screwed up your quiz since you do not see quizzing system variables being
updated. I cannot confirm it is due to deleting titles however. Try to copy
some question slides to a blank project with original master slides to
check if system variables updatr?
Thanks, Lilybiri, for your time and ideas!
I made new blank project with original master slides, and again nor variables, nor results show score.
But then I made new blank project with original master slides and simple question slides (not from Question Pool) and everything is great, variables and result page are correct.
So, Question pool with random questions causes this weired behavior.
Flash format now is working - for some of question slides I had different timings in Question Pool (3 sec) and in project Filmstrip (1 sec). Now timing is equal and Flash format output is working correctly,
However HTML acts the same.
I've run into similar results when copying and pasting quiz text from a word document, captivate appears rather sensitive to word's hidden / special characters. I've gotten in the habit of copying word text into notepad as a first step, then copy and paste works better!
Thanks for sharing, BDuckWorks, but it won't be my case - I import questions from txt file.
