3 Replies Latest reply on Jan 10, 2007 12:43 PM by wgb14
    Director and GPS?
    Level 7
      Hi all,
      I need to create a director file that responds to GPS location.
      Can anyone give any advice or point me in the right direction (no pun
      intended!)
      I need to know what kind of hardware i need to get a signal, and how i get
      the GPS coords into director?
      Any ideas anyone?
      Im using a Windows PC (xp) with Director MX or MX2004 (have both)
      Cheers,
      Tim.
        • 1. Re: Director and GPS?
          johnAq Level 1
          Probably the most likely solution is a GPS unit that can connect to a PC via RS-232 (serial port). Even though these ports are becoming replaced by USB, you can get a USB - to RS232 attachment. You can then use an xtra such as DirectCommunication or Serial Xtra to comunicate with the device using text based messaging
          You can find a list of available xtras at
          http://www.updatestage.com/products_table.html
          hth
          johnAq
          • 2. Re: Director and GPS?
            Level 7
            Thanks, will look into these...
            Do you know if I can control (read) a USB GPS device with these xtras?
            It seems the serial versions also require power from a ps2 port.... Ive no
            serial or PS2 ports on the laptop...plenty of usb!!!
            Cheers
            Tim.
            "johnAq" <webforumsuser@macromedia.com> wrote in message
            news:eo1jv0$6i7$1@forums.macromedia.com...
            > via
            > USB,
            > text
            > based messaging
            > hth
            > johnAq
            • 3. Re: Director and GPS?
              wgb14 Level 1
              There is an ActiveX control that you can use in Director and GPS-enable your applications. I have done this in the past and it works perfectly. Email me at idoumanis@yahoo.gr and i will forward you the code
