I have an older photoshop CS2 and want to install in on my new iMac operating @ 10.9.5. Can it be done..? I tried but it won't install.. any ideas?
No.
CS2 only runs on Macs with the following specs:
Modern Intel-based Macs running OS X 10.7 or later (such as yours) cannot run CS2.
Your options:
for compatibility info you can check here, http://roaringapps.com/apps:table
and to activate:
Error: "Activation Server Unavailable" | CS2, Acrobat 7, Audition 3
Geoffrey,
Even if you have not used up both activations, you will need to use the link provided above for activation since the original activation server has been discontinued.
Adobe has disabled the activation server for CS2 products. These products were released more than seven years ago and do not run on many modern operating systems. Customers who legitimately purchased CS2 and need to maintain their current use of these products may use the serial numbers provided during the download.
Pattie
No.
Your options:
