Does anyone know the process for activating a very old version (CS3)? I want to use Ultra and as far as I know, CS3 is the only version that this works with.
If anyone can tell me how to use Ultra, which was bundled with CS3, with CS5.5 or CS6, I would be grateful.
Thank you,
check your hosts file.
for help with that and more info about the possible causes of the problem you're having, Sign in, activation, or connection errors | CS5.5 and later, Acrobat DC
the steps required to activate cs3,4,5,6 are the same as they've always been: start the installation and enter your serial number when prompted.
if you're having a problem, describe it.
Thank you for the quick reply.
The problem that I am having is that when I click the button to activate it online, I get a message that says cannot connect. When I try to call to activate it by phone, the numbers are no longer in service. I am guessing that Adobe no longer supports that product. Even so, I paid for the product and should be able to use it which, I cannot until I can activate it.
