2 Replies Latest reply on May 28, 2015 11:53 PM by Wpp Id
    app.doScript(...) timeout?
    Wpp Id
      Hi all,
      I'm struggling with a strange issue. Maybe it's a simple problem, but I can't find a solution.
      I've created a simple function sendEmail(...) that makes an app.doScript(...) call (using Visual Basic Script language).
      In particular I'm using Visual Basic "CDO.Message" Object (see the example below).
      var sendEmail = '';
      sendEmail +='Set emailObj = CreateObject("CDO.Message")\r';
      sendEmail +='...etc...';
      app.doScript(sendEmail, ScriptLanguage.VISUAL_BASIC);
      I call sendEmail(...) function every time a script finishes or every time a script get an error.
      This code works fine, but I'm having some issues when the script execution take a long time.
      It happens that, if the script takes about 2 hours or more time, the email is not sent. It's strange because the script end correctly and doesn't break to this function.
      My last test was that:
      var time = 1000; //1 second
      while(time < 999999999999){
          $.sleep(time);
          sendEmail("sleep time: " + (time/60000));  //Print to the email body the sleep time in minutes
          time += 300000; //Add 5 minutes
      My last email received from this test showed:
      sleep time: 150 //2 hours 30 minutes
      And then anything else!!
      Do you have any ideas about that? I'm really confused about that!
      Regards,
      Daniel
        • 1. Re: app.doScript(...) timeout?
          Trevorׅ Adobe Community Professional
          Well that test must of really taken a long time to do!
          It's hard to say without the entire code but it looks like maybe the a limit to how long you can set the sleep for.
          Try either adding a try / catch like this
          try {$.sleep(time)}catch (e) {for (n in e) $.writeln(n + ": " +e[n])}
          Or better still just try in separate 1 line script  (I was very lazy with the enter key :-)
          try {$.writeln(new Date); $.sleep(10000000000000); $.writeln('Slept");}catch (e) {$.writeln(new Date);for (n in e) $.writeln(n + ": " +e[n])}
          HTH
          Trevor
          • 2. Re: app.doScript(...) timeout?
            Wpp Id Level 1
            Hi Trevor,
            thank you for your reply.
            Yes...this test took about 2/3 days! :-)
            Ok, I will try your suggestions.
            Regards,
            Daniel
