7 Replies Latest reply on Jan 9, 2007 8:21 AM by Newsgroup_User
    onEnterframe troubles
    MatMaar
      Hi
      I call a function in one of my scripts and in that script 2 onEnterFrame function are placed.
      Now when I call that function, flash don't execute the onEnterframe function.
      Hope somebody can help me here.
        • 1. Re: onEnterframe troubles
          DazFaz Level 1
          I can see there are 2 possible reasons why it’s not working:
          1. The actual "imageCentral_mc" does not exist at the time of the function call
          2. There is a relative path issue.
          • 2. Re: onEnterframe troubles
            MatMaar Level 1
            imageCentral_mc and imageRight_mc are in the root of the movie and on frame 1 of the movie.
            I tried _root.imageRight_mc an I am on frame 1 of the movie, so.....
            • 3. Re: onEnterframe troubles
              MatMaar Level 1
              The part where it says loadMovie, does execute.
              And I use the same path for the onEnterFrames. That's why it is strange to me that this does not work
              • 4. Re: onEnterframe troubles
                Level 7
                That is actually *why* it doesn't work. When you load content to a
                movieClip, all of that clip's parameters (including for instance it's
                enterFrame handler) are overwritten. Load your images into your clips using
                a preloader - when the images have loaded, *then* assign the enterFrame
                handlers...
                Remove '_spamkiller_' to mail
                • 5. Re: onEnterframe troubles
                  MatMaar Level 1
                  I call this script from this script. This explains maybe a bit more.
                  • 6. Re: onEnterframe troubles
                    MatMaar Level 1
                    handlers...
                    So If I put the loadMovie before the functions, this will work?
                    Sorry but fi I do this, nope... nothing Not even the trace within the onEnterframe function.
                    • 7. Re: onEnterframe troubles
                      Level 7
                      No, that's not enough. Put the loadMovie assigning the enterFrame, but ALSO,
                      wait for the image to *actually load*
