4 Replies Latest reply on May 29, 2015 8:17 AM by Ballistik
    Indesign cc - Duplicate keyboard shortcut not working
    Ballistik
      Hey all,
      Hopefully I can get an answer to this. It's not a massive issue, it just messes with workflow and as such is quite annoying!
      The problem is with other versions of Indesign you could hold down 'Command+Alt+Shift+D to duplicate an object as many times as you would like. I tend to use this function quite a bit. However with the release of InDesign CC the keyboard shortcut seems to no longer be functioning. I can go to the Edit Menu and use the Duplicate function there...(the keyboard shortcut command is sitting beside the word still), but this is quite inefficient when you want to duplicate an object 25+ times. Anyone else having this trouble? Is there any way to get this function working?
      Thanks!
      Using OSX 10.9.5
