7 Replies Latest reply on Jan 4, 2007 1:36 PM by Peter Lorent
    target_mc._height
      hi if got a little problem how can I use the target_mc._height outside of my onloadinit function? i have to add it to my var K to keep me on the right height?
      var k = 10;
      //variabele voor het bijhouden van de hoogte
      var j = 10;
      //variabele voor het bijhouden van dfe depth
      function loadXML(loaded) {
      if (loaded) {
      myTBX.contentPath = "content_holder";
      xmlNode = this.firstChild;
      date = [];
      titel = [];
      entry = [];
      image = [];
      total = xmlNode.childNodes.length;
      for (i=0; i<total; i++) {
      date = xmlNode.childNodes.childNodes[0].firstChild.nodeValue;
      titel = xmlNode.childNodes.childNodes[1].firstChild.nodeValue;
      entry = xmlNode.childNodes.childNodes[2].firstChild.nodeValue;
      image = xmlNode.childNodes.childNodes[3].firstChild.nodeValue;
      //formatting voor datums
      var my_fmt2 = new TextFormat();
      my_fmt2.font = "Verdana";
      my_fmt2.size = 11;
      my_fmt2.underline = true;
      my_fmt2.color = 0xFFCC33;
      //Yellow
      my_fmt2.bold = true;
      var metricsDate:Object = my_fmt2.getTextExtent(date , 100);
      thisTextBox = myTBX.content.createTextField("tbxDate"+i, 20+j, 20, k, 100, metricsDate.textFieldHeight);
      j++;
      k += 15;
      //tussen titel en datum
      thisTextBox.background = false;
      thisTextBox.border = false;
      thisTextBox.backgroundColor = 0xcccccc;
      //light grey
      thisTextBox.borderColor = 0x000000;
      //black
      thisTextBox.multiline = true;
      thisTextBox.wordWrap = true;
      thisTextBox.text = date
      thisTextBox.setTextFormat(my_fmt2);
      var metricsTitel:Object = my_fmt2.getTextExtent(titel , 300);
      thisTextBox1 = myTBX.content.createTextField("tbxTitel"+i, 20+j, 20, k, 300, metricsTitel.textFieldHeight);
      j++;
      k += 15;
      //tussen titel en txt
      var my_fmt3 = new TextFormat();
      my_fmt3.font = "Verdana";
      my_fmt3.size = 11;
      my_fmt3.underline = true;
      my_fmt3.color = 0xFF9900;
      //orange
      my_fmt3.bold = true;
      thisTextBox1.background = false;
      thisTextBox1.border = false;
      thisTextBox1.backgroundColor = 0xcccccc;
      //light grey
      thisTextBox1.borderColor = 0x000000;
      //black
      thisTextBox1.multiline = true;
      thisTextBox1.wordWrap = true;
      thisTextBox1.text = titel
      thisTextBox1.setTextFormat(my_fmt3);
      var my_fmt = new TextFormat();
      my_fmt.font = "Verdana";
      my_fmt.size = 10;
      my_fmt.color = 0x000000;
      //grey
      var metricsText:Object = my_fmt.getTextExtent(entry , 450);
      thisTextBox2 = myTBX.content.createTextField("tbxText"+i, 20+j, 20, k, 450, metricsText.textFieldHeight);
      j++;
      k += metricsText.textFieldHeight;
      thisTextBox2.background = false;
      thisTextBox2.border = false;
      thisTextBox2.backgroundColor = 0xcccccc;
      //light grey
      thisTextBox2.borderColor = 0x000000;
      //black
      thisTextBox2.multiline = true;
      thisTextBox2.wordWrap = true;
      thisTextBox2.html = true;
      thisTextBox2.htmlText = entry
      thisTextBox2.setTextFormat(my_fmt);
      k += 15;
      //eindhoogte tussen enrty
      if (image != "undefined") {
      var mci:MovieClip = myTBX.content.createEmptyMovieClip("mc"+i, 40+j);
      j++;
      var image_mcl:MovieClipLoader = new MovieClipLoader();
      var mclListener:Object = new Object();
      mclListener.onLoadInit = function(target_mc:MovieClip) {
      trace(target_mc._height); // <--here i have it
      image_mcl.addListener(mclListener);
      image_mcl.loadClip(image
      , mci);
      mci._y = k;
      mci._x = 30;
      //k+= target_mc._height + 10; // <-- here's my problem
      xmlData = new XML();
      xmlData.ignoreWhite = true;
      xmlData.onLoad = loadXML;
      xmlData.load(" http://localhost/test/get_news_to_xml.php");
        • 1. Re: target_mc._height
          arunbe Level 1
          Hi ,
          Just you change the value of k inside the onLoadInit funcion.
          Look the code...
          • 2. Re: target_mc._height
            thanks for the help but it isn't working eather
            • 3. Re: target_mc._height
              Peter Lorent Level 2
              Post a link to a zip with all the files (fla,images,xml).
              • 4. target_mc._height
                here 's the fla,
                only the fla , the xml and images are generated through php so it will work like this ;-)
                and thx for the help
                • 5. Re: target_mc._height
                  Well, from what I read in the code you are positioning the image with the text block? There you make an error based on the fact that you expect the function to wait for the image to load and then proceed with the next block. But it doesn't. As soon as the loadClip() is fired, the for loop continues.
                  So, running the program gives the following results when you trace k:
                  k at the bottom of the for loop: 117
                  k at the bottom of the for loop: 188
                  k at the bottom of the for loop: 259
                  k at the bottom of the for loop: 342
                  k at the bottom of the for loop: 413
                  k at the bottom of the for loop: 496
                  k at the bottom of the for loop: 567
                  k at the bottom of the for loop: 662
                  k at the bottom of the for loop: 841
                  k at the bottom of the for loop: 948
                  Then the for loop ends but the MovieClipLoader is still working and then traces:
                  200
                  k in onLoadInit(): 948
                  200
                  200
                  k remains 948 there because the for loop already stopped.
                  So, wrong setup. You need to code this differently
                  • 6. target_mc._height
                    I got it! thx for the help anyway ;-)
                    i made an extra table in my msql with my image heigt (taken and stored when uploading the image) and then send in array to my flash
                    so that's my working code now:
                    • 7. Re: target_mc._height
                      Nice solution. And works because it's independent from the MovieClipLoader.
                      Goed gedaan jochie
