4 Replies Latest reply on May 29, 2015 12:47 AM by BEGINNER_X
    Open multiple Files as per Trim Size
    BEGINNER_X Level 3
      Hi All,
      Please help for my request, this should be very urgent.
      Request:
      1. User Select Folder
      2. Open all Files
      3. Collect Trim Size (document width) + Document Name
      4. Sort the Document Width (lower value to higher value)
      5. Again open the Files as per minimum document width
      Trying Script:
      #target Indesign
      var  myFolder = Folder.selectDialog("Select the Folder contains Indesign Files");
      var myFiles = myFolder.getFiles("*.indd");
      myWidthArray = new Array();
      for(i=0; i<myFiles.length; i++)
          app.open(myFiles[i]);
          app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
          var myDocument_Width = Math.round(app.activeDocument.documentPreferences.pageWidth);
          var myReq = myDocument_Width + app.activeDocument.name;
          myWidthArray.push(myReq)
          app.activeDocument.close();
      alert(myWidthArray)
      var myPoints = myWidthArray;
      myPoints.sort(function(a, b){return a-b});
      alert("myPoints: " + myPoints)
      //here need help
      for(k=0; k<myPoints.length; k++)
          app.open(myPoints[k].document.name)
      Siraj
        • 1. Re: Open multiple Files as per Trim Size
          Chinnadk Level 4
          Hi Siraj,
          Is this you need?
          #target Indesign
              myWidthArray[i] = [];
              myWidthArray[i].push(myDocument_Width)
              myWidthArray[i].push(app.activeDocument.name)
          myWidthArray.sort();
          //here need help
          for(k=0; k<myWidthArray.length; k++)
              app.open(File(myFolder + "/"+ myWidthArray[k][1]));
          Regards,
          Chinna
          • 2. Re: Open multiple Files as per Trim Size
            BEGINNER_X Level 3
            Hi Chinna,
            Thank you for your immediate response...
            Could you please see the alert, this should not sort correctly.
            For testing purpose, I created 4 files and test it.
            I alert in the provided script:
            var myOutput = myWidthArray.sort();
            alert(myOutput)
            Please look into this.
            But my need is
            40,small_tsserd.indd, 210,bbb.indd, 400,abcd.indd, 1200,large_yyyde.indd
            Again thanks for your support.
            • 3. Re: Open multiple Files as per Trim Size
              milligramme Level 3
              Hi try this code
              #target Indesign
              var myWidthArray = new Array();
              for(var i=0; i<myFiles.length; i++)
                  // store the values as object
                  var myReq = {w:myDocument_Width, d:app.activeDocument.name};
                  myWidthArray.push(myReq);
              alert(myWidthArray.toSource());
              // sort by width
              myPoints.sort(function(a, b){return a.w * 1-b.w * 1});
              alert("myPoints: " + myPoints.toSource());
              //here need help
              for(var k=0; k<myPoints.length; k++)
                  // reopen documents in selected folder
                  // open with fullpath
                  app.open(new File(myFolder + '/' + myPoints[k].d));
              thank you
              • 4. Re: Open multiple Files as per Trim Size
                BEGINNER_X Level 3
                Hi Chinna/Milligramme,
                Excellent support in your busy schedule.
                Milli: Your coding is working fine in my end.
                Again Thanks a lot guys!!!!
