0 Replies Latest reply on May 28, 2015 11:51 PM by sowmiyavaithi
    I need to have this Applescript translated so I can use on my Windows system. Is there anyone out there who could do this for me?
    sowmiyavaithi
      --empty list
      copy "" to myList
      tell application "Adobe InDesign CS6"
          activate
          set myDoc to active document
          --set rulers to pixels
          set zero point of myDoc to {0, 0}
          set horizontal measurement units of view preferences of myDoc to pixels
          set vertical measurement units of view preferences of myDoc to pixels
          --ID Document name
          set myDocname to name of myDoc
          --start the list
          copy myDocname & ":" & return & return to myList
          tell myDoc
              repeat with myPage from 1 to count every page
                  tell page myPage
                      --all of the doc page items as a list
                      set myPageList to all page items
                      repeat with pitem from 1 to (count items of myPageList)
                          --select every item on the epage
                          select item pitem of myPageList
                          try
                              --a=Y, b=X, width=d-c, height= c-a
                              set {a, b, c, d} to geometric bounds of item pitem of myPageList
                              --remove as integer if you want the dimensions as numbers—not rounded
                              set y to a as integer
                              set x to b as integer
                              set w to d - b as integer
                              set h to c - a as integer
                              -- page number
                              set pageNumber to name
                              --the page item's info added to the list
                              set myItem to "P:" & pageNumber & "  " & "X:" & x & "  " & "Y:" & y & "  " & "W:" & w & "  " & "H:" & h & return
                              copy myList & myItem & return to myList
                          end try
                      end repeat
                  end tell
              end repeat
          end tell
          --display the list
          if myList is not "" then
              display dialog myList
          end if
      end tell
