1 2 Previous Next 54 Replies Latest reply on Sep 2, 2016 3:00 AM by karanjugmohun
    Save PDF File Name as Field Name in PDF
    Underz
      Hi all,
      I've read through this thread : https://acrobatusers.com/tutorials/how-save-pdf-acrobat-javascript and I still can't figure this out.
      I want to have a custom save button on my fillable form PDF, and have it save the file name with the fields in my form.  The field names are "RequestedBy" , "NameofEvent" , "EventStartmdyy"
      so as an example, the pdf is filled out and returned to me with its default pdf name as "Event Request Form Update-1.pdf" , then I get it, and click the button, then it saves it as "DarinVegasTradeshowJune152015.pdf" and saves to a specific folder every time.
      I read about getting trusted access and put it into a javascript either in the folder or on my computer? My co-worker and I will be the only person to save these, so it's only on two machines.
      Hope you can assist.
      Thank you
        • 1. Re: Save PDF File Name as Field Name in PDF
          Karl Heinz Kremer Adobe Community Professional
          The trusted function needs to be stored in a folder level script, so it needs to go either into the system level or the user level JavaScripts folder.
          • 2. Re: Save PDF File Name as Field Name in PDF
            Underz Level 1
            Do you have an example of a trusted function? I am unaware of what that is, or looks like. Also, where would the system level default location be? Is the user level the 'folder' that the pdf is in?
            I then also don't know how to code to suit my needs, maybe the trusted part made my test code not work? i am not sure.
            thanks for your help
            • 3. Re: Save PDF File Name as Field Name in PDF
              The tutorial you've linked to contains the implementation for such a trusted function. This tutorial explains where to save such scripts: https://acrobatusers.com/tutorials/folder_level_scripts
              • 4. Re: Save PDF File Name as Field Name in PDF
                Underz Level 1
                Thanks, found the location on my computer, however I am still not 100% clear on WHAT code goes inside that javascript file?
                as a test, I put this code in a config.txt file, then saved as config.js
                [code]
                var mySaveAs = app.trustedFunction(
                  function(oDoc,cPath,cFlName)
                  // Ensure path has trailing "/"
                  cPath = cPath.replace(/([^/])$/, "$1/");
                  try{
                  oDoc.saveAs(cPath + cFlName);
                  }catch(e){
                  app.alert("Error During Save");
                [/code]
                I then used the second part of that, and put that into my javascript inside the pdf, but it says "syntaxerror: missing )  after arugment list 5 : at line 6.  I put a ) there and didnt help.
                am I getting on the right track? I have not much confidence in this at this point, as i am not seeing how this will work for my application of renaming a file via button
                • 5. Re: Save PDF File Name as Field Name in PDF
                  Underz Level 1
                  sorry, this is the code inside the javascript in the PDF, can't find the edit button on this forum
                  // First make sure the function exists
                  if(typeof(mySaveAs) == "function"){
                      mySaveAs(this,this.path);
                  }else{
                      app.alert("Missing Save Fucntion" + Please contact forms administrator");
                  • 6. Re: Save PDF File Name as Field Name in PDF
                    After reviewing the tutorial again, I found out that the folder level code does not run correctly in a newer version of Acrobat. Use this instead:
                      function(oDoc, cPath, cFlName) {
                      try {
                      app.beginPriv();
                      app.endPriv();
                      } catch (e) {
                      app.alert("Error During Save - " + e);
                    And then, there is a syntax error in the code that needs to run in your document, but in addition to that, it is not using the folder level script correctly. Try to use this instead:
                    // determine the directory path for the current document
                    var directory = this.path.substring(0, this.path.lastIndexOf('/') +1);
                    if (typeof(mySaveAs) == "function") {
                      mySaveAs(this, directory, "newName.pdf");
                    } else {
                      app.alert("Missing Save Function. Please contact forms administrator ");
                    Also, make sure that you are using device independent paths for your filenames. When doing this on a Windows system, you would not use "C:\directory\file.pdf", it would be "/c/directory/file.pdf".
                    • 7. Re: Save PDF File Name as Field Name in PDF
                      Underz Level 1
                      Ok, still not working for me.
                      When I do your second code in my pdf, it gives me the alert error message..
                      I put your first code in all places I could think of, both appdata's, the folder itself and even in the pdf javascript area.  still not saving, still not renaming to 'newname.pdf'
                      what am I doing wrong ??
                      • 8. Re: Save PDF File Name as Field Name in PDF
                        Which operating system and what version of Acrobat are you running?
                        • 9. Re: Save PDF File Name as Field Name in PDF
                          Underz Level 1
                          I'm on Windows 7, Adobe Acrobat X - 10.1.14.11
                          I'm also at work, but I imagine these won't need network assistance...
                          • 10. Re: Save PDF File Name as Field Name in PDF
                            The application level directory is either "C:\Program Files\Adobe\Acrobat 10.0\Acrobat\Javascripts" or "C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Javascripts" (depending on whether you are running a 32bit or 64bit operating system). The user level directory is "C:\Users\<user name>\AppData\Roaming\Adobe\Acrobat\10.0\JavaScripts"
                            Did you install the script in either one of these? If the "JavaScripts" directory does not exist, you will have to create it.
                            • 11. Re: Save PDF File Name as Field Name in PDF
                              Underz Level 1
                              ok so I put it in both locations, and pasted your code in my PDF javascript... nothing worked yet. starting to feel like a fool haha, I appreciate your help and patience!
                              1. // determine the directory path for the current document
                              2. var directory = this.path.substring(0, this.path.lastIndexOf('/') +1);
                              3.
                              4.
                              5. if (typeof(mySaveAs) == "function") {
                              6.   mySaveAs(this, directory, "newName.pdf");
                              7. } else
                              8.   app.alert("Missing Save Function. Please contact forms administrator ");
                              then i also did
                              3. if (typeof(mySaveAs) == "function") {
                              4.   mySaveAs(this, //HA123/Shares/Marketing_bridge/Darin/`MasterTracker/EventRequestForms/, "newName.pdf");
                              5. } else {
                              6.   app.alert("Missing Save Function. Please contact forms administrator ");
                              7. }
                              then i also tried
                              4.   mySaveAs(this, directory, "//HA123/Shares/Marketing_bridge/Darin/`MasterTracker/EventRequestForms/newName.pdf");
                              5. } else {
                              7. }
                              p.s. I am going home for the weekend, I will return to this on Monday.  Have a great weekend and again, appreciate the help and patience with me on this!
                              • 12. Re: Save PDF File Name as Field Name in PDF
                                Underz Level 1
                                Good morning,
                                anymore idea's for my problem?
                                • 13. Re: Save PDF File Name as Field Name in PDF
                                  Saying "nothing worked" isn't really helping us help you... What exactly is the result when you run the code? Are there any error messages in the console? Does it save the file at all but using the wrong name or in the wrong location? You need to be be more specific if you want to get any help...
                                  • 14. Re: Save PDF File Name as Field Name in PDF
                                    Underz Level 1
                                    good morning.
                                    Sorry, I figured I gave enough information based on the entire thread, I will try and be more informative for you.
                                    It does not save at all.  I make a change, hit the button and try to exit, and it still asks me to save.
                                    Debugger says
                                    Acrobat EScript Built-in Functions Version 10.0
                                    Acrobat SOAP 10.0
                                    TypeError: redeclaration of const mySaveAs
                                    1:Field:Mouse Up
                                    1:Field:Mouse Up
                                    code in the button is
                                    1. var mySaveAs = app.trustedFunction(
                                    2.   function(oDoc, cPath, cFlName) {
                                    3.   // Ensure path has trailing "/"
                                    4.   cPath = cPath.replace(/([^/])$/, "$1/");
                                    5.   try {
                                    6.   app.beginPriv();
                                    7.   oDoc.mySaveAs(cPath + cFlName);
                                    8.   app.endPriv();
                                    9.   } catch (e) {
                                    10.   app.alert("Error During Save - " + e);
                                    11.   }
                                    12.   }
                                    13. );
                                    14. // determine the directory path for the current document
                                    15. var directory = this.path.substring(0, this.path.lastIndexOf('/') +1);
                                    16.
                                    17.
                                    18. if (typeof(mySaveAs) == "function") {
                                    19.   mySaveAs(this, directory, "//HA123/Shares/Marketing_bridge/Darin/`MasterTracker/EventRequestFormsnewName123.pdf");
                                    20. } else {
                                    21.   app.alert("Missing Save Function. Please contact forms administrator ");
                                    22. }
                                    • 15. Re: Save PDF File Name as Field Name in PDF
                                      The mySaveAs function needs to exist in the folder-level script. You should not declare it again in the code you're running from the console or button or whatever you use.
                                      • 16. Re: Save PDF File Name as Field Name in PDF
                                        Underz Level 1
                                        Ok I figured it out... I'll try and describe my efforts to get this to work, in-case someone else finds this on the web.  Thank you all who have helped me in this thread.
                                        I pasted this code into a text file, saved it as a javascript (.js file), in the following locations Program Files > Adobe > Acrobat > Javascript, I also pasted it into the folder where I will be saving the file.
                                        5.   try
                                        6.   app.beginPriv();
                                        7.   oDoc.saveAs(cPath + cFlName);
                                        8.   app.endPriv();
                                        9.   } catch (e) {
                                        11.   }
                                        12.   }
                                        13. );
                                        Then, I created a button, added a javascript to it.  the "this.getField's are looking for field names in my PDF, "RequestedBy" is a field in my PDF that has my sales managers name, it then adds a space beside it (+ " " +), then goes to the next field I want.  so when I fill out the pdf, it then saves it as SalesManager EventName June 1 2015.pdf.
                                        4.   mySaveAs(this, directory, this.getField("RequestedBy").value + " " + this.getField("NameofEvent").value + " " + this.getField("EventStartmdyy").value + ".pdf");
                                        5. } else {
                                        7. }
                                        Hope that helps anyone else looking to do this, it's fairly easy once you know where to save the javascripts (and what to put in it), then edit another javascript code to meet your needs.
                                        Thank you!
                                        • 17. Re: Save PDF File Name as Field Name in PDF
                                          Underz Level 1
                                          Actually one thing, maybe you can help with it?
                                          I will be getting these forms via email, and I would like to open the form they return, and hit save, then it saves it into my directory.  Right now, I have to save this in the directory I want, then hit save, then it works as I want....as you can see it's an added step that I hope I can eliminate....
                                          I tried messing around with the = this.path ... but didn't work.
                                          Code;
                                          directory I want it to be saved in;
                                          \\HA123\Shares\Marketing_bridge\Darin\`MasterTracker\EventRequestForms
                                          • 18. Re: Save PDF File Name as Field Name in PDF
                                            You need to find out the internal path of that folder and then specify it as the second parameter for mySaveAs.
                                            The best way to do that is to open a PDF file that's inside that folder, and then run this command in the JS console:
                                            this.path
                                            Then copy the first part of the output, until the file-name, and use it directly in your code.
                                            It will probably be something like this:
                                            • 19. Re: Save PDF File Name as Field Name in PDF
                                              Underz Level 1
                                              ok I've tried a bunch of things, and haven't got it to work. I tried pasting it in the javascript folder level, tried inside the code...nothing...
                                              Where exactly do you paste that internal? I knew to switch the /'s ... but not sure exactly where. can you post an example of the code?
                                              appreciate it
                                              • 20. Re: Save PDF File Name as Field Name in PDF
                                                var directory = "/HA123/Shares/Marketing_bridge/Darin/`MasterTracker/EventRequestForms/";
                                                var fileName = "newFile.pdf";
                                                mySaveAs(this, directory, fileName);
                                                • 21. Re: Save PDF File Name as Field Name in PDF
                                                  Underz Level 1
                                                  hmm, not working, gives me an error
                                                  "Error during Save - UnsupportedValueError: Value is unsupported. ======> Parameter cPath
                                                  my code , I've also tried the directory without the + "/"; ...and I have also tried adding a / after the /1        -      neither worked.
                                                  2. var directory = "//HAUCACAM0007VS/Shares/Marketing_bridge/Darin/`MasterTracker/EventRequestForms/1" + "/";
                                                  5. } else {
                                                  7. }
                                                  I have no added/changed anything in the Javascript.
                                                  can you see where I went wrong ?
                                                  • 22. Re: Save PDF File Name as Field Name in PDF
                                                    It's likely the file-name contains invalid characters.
                                                    • 23. Re: Save PDF File Name as Field Name in PDF
                                                      Underz Level 1
                                                      All letters/spaces/numbers.
                                                      I took out the spaces and still nothing.  so after I changed the code from
                                                      1. var directory = this.path.substring(0, this.path.lastIndexOf('/') +1);
                                                      to
                                                      1. var directory = "//HAUCACAM0007VS/Shares/Marketing_bridge/Darin/`MasterTracker/EventRequestForms/1";
                                                      something went wrong.... the folders exist.
                                                      • 24. Re: Save PDF File Name as Field Name in PDF
                                                        Add a slash at the end of the directory variable.
                                                        • 25. Re: Save PDF File Name as Field Name in PDF
                                                          Underz Level 1
                                                          I did that too, tried with and without.  I tried without quotations as well, but that gives me an error also.
                                                          • 26. Re: Save PDF File Name as Field Name in PDF
                                                            Sorry, I can't help you beyond that. You need to debug the code until you find the source of the problem.
                                                            • 27. Re: Save PDF File Name as Field Name in PDF
                                                              Underz Level 1
                                                              Thanks for trying... all debugger says is undefined. ;(
                                                              • 28. Re: Save PDF File Name as Field Name in PDF
        Did it work when you specified the path by accessing the path property? If so then there's something wrong with the way you defined the directory variable.
        Did it work when you specified the file-name using a hard-coded string ("newFile.pdf")? If so then there's something wrong with the combined name from the form fields.
        • 29. Re: Save PDF File Name as Field Name in PDF
        Underz Level 1
        This code works perfectly, and takes my fields and uses them as the file name. So if I can't figure out how to save to a specific directory, it will be ok, but having things perfect is ideal!
        Any other variation to the Path (which I want to be customized to point to 1 local directory) screws it up.
        3.
        4.
        6.   mySaveAs(this, directory, this.getField("RequestedBy").value + " " + this.getField("NameofEvent").value + " " + this.getField("EventStartmdyy").value + ".pdf");
        7. } else {
        9. }
        • 30. Re: Save PDF File Name as Field Name in PDF
        Follow my instructions above to get the correct syntax for the folder name.
        • 31. Re: Save PDF File Name as Field Name in PDF
        Underz Level 1
        I tried the following;
        The correct syntax I got, based on the debugger for "this.path" returned
        /HAUCACAM0007VS/Shares/Marketing_bridge/Darin/`MasterTracker/EventRequestForms/1/test.pdf
        so I changed the code from this
        to this
        var directory = "/HAUCACAM0007VS/Shares/Marketing_bridge/Darin/`MasterTracker/EventRequestForms/1/"
        and it worked.  I swear I tried that, and a few variations before.
        Very interesting.  I can send myself this PDF, open it without saving, click the save and it points to my directory I wanted.
        Yay! Solved!
        Thank you try67!
        Again, for the sake of people googling how to do this...
        5.   try {
        6.   app.beginPriv();
        8.   app.endPriv();
        9.   } catch (e) {
        11.   }
        12.   }
        13. );
        2. var directory = "/HAUCACAM0007VS/Shares/Marketing_bridge/Darin/`MasterTracker/EventRequestForms/1/"
        5. } else {
        7. }
        Thank you!
        • 32. Re: Save PDF File Name as Field Name in PDF
        I think had two slashes at the start of the path before, which is probably
        what prevented it from working correctly.
        • 33. Re: Save PDF File Name as Field Name in PDF
        Underz Level 1
        Ok this is not working anymore, my company upgraded to adobe acrobat 11, and now my error says "Missing Save Function, Please contact forms administrator"
        any idea to get this working again? nothing changed except new program.
        I put the javascript into the new adobe 11 javascript folder also.
        thx all
        • 34. Re: Save PDF File Name as Field Name in PDF
        The error message suggests that the function defined in the folder level script is not known, which means that the folder level script did either not execute, or that an error occurred while loading that script file and because of that, the execution of that script was stopped. Do you see any error messages in the JavaScript console? If not, make sure that your script is actually in the correct location. Take a look here for information about how to determine where a folder level script needs to be stored: https://acrobatusers.com/tutorials/print/entering-folder-level-scripts
        • 35. Re: Save PDF File Name as Field Name in PDF
        After adding a folder level function requires a restart of Acrobat or Reader since the scripts in these files are only loaded into the memory used by Acrobat/Reader at the startup of the application and not updated as the contents of the folders are updated.
        • 36. Re: Save PDF File Name as Field Name in PDF
        zacharyb86705730 Level 1
        I am currently trying to achieve the same result.  I used the script below in my Javascript folder:
        try {
        app.beginPriv();
        app.endPriv();
        } catch (e) {
        I then used this script for the button in LiveCycle:
        var directory = "/c/temp/"
        mySaveAs(this, directory, this.getField("UNID").value + ".pdf");
        } else {
        Nothing seems to happen.  I don't get the error message telling me to contact the adminstrator and the file won't save to my temp folder on the c drive.  Any ideas whats going on here?
        • 37. Re: Save PDF File Name as Field Name in PDF
        You can't use scripts written for Acrobat files on LCD files. The objects, properties and methods are very different in both environments.
        For questions about LCD files try the LCD forum: LiveCycle Designer
        • 38. Re: Save PDF File Name as Field Name in PDF
        Thanks!  I switched the button javascript from LCD to Acrobat which worked as I thought.  My next task is try to figure out how to save a multipage document to different directories when the button is clicked.  Any ideas where to start looking for that?
        • 39. Re: Save PDF File Name as Field Name in PDF
        Do you mean split it to multiple folders, or just save multiple copies in various locations?
        1 2 Previous Next
