8 Replies Latest reply on May 29, 2015 10:59 AM by Jon Fritz II
    Help on <head> section and It IE codes/Modernizer
    MSMSG
      I want to know if I need to include the following in the head section of my html pages if I am not customizing modernizer
      The way I read it, it says to remove it if you are customizing it?
      <!doctype html>
      <!--[if lt IE 7]> <html class="ie6 oldie"> <![endif]-->
      <!--[if IE 7]>    <html class="ie7 oldie"> <![endif]-->
      <!--[if IE 8]>    <html class="ie8 oldie"> <![endif]-->
      <!--[if gt IE 8]><!--> <html class="">
      <!--<![endif]-->
      <head>
      To learn more about the conditional comments around the html tags at the top of the file:
      paulirish.com/2008/conditional-stylesheets-vs-css-hacks-answer-neither/
      Do the following if you're using your customized build of modernizr (http://www.modernizr.com/):
      * insert the link to your js here
      * remove the link below to the html5shiv
      * add the "no-js" class to the html tags at the top
      * you can also remove the link to respond.min.js if you included the MQ Polyfill in your modernizr build
      <!--[if lt IE 9]>
      <script src="http://html5shiv.googlecode.com/svn/trunk/html5.js"></script>
      <![endif]-->
      <script src="respond.min.js"></script>
