3 Replies Latest reply on May 8, 2006 5:58 AM by Newsgroup_User
    .cct files dosnt work on websites =/
    mrmille Level 1
      Hi
      i've created a major presentation wich uses external cast's. However, the cct files will not link or work properly in the presentation.
      If i create a projector everything is fine. But for webuse it freaks out.
      Any known issues?
        • 1. Re: .cct files dosnt work on websites =/
          mrmille Level 1
          and,
          is there a way do delete cast members?
          external members that is, i dont want it anymore =)
          • 2. Re: .cct files dosnt work on websites =/
            Level 7
            On Mon, 08 May 2006 08:21:27 GMT, mrmille posted in
            macromedia.director.basics:
            > Hi
            > out.
            I've never seen that symptom. What makes you think it freaks out? What do you
            mean by that? Is there a browser, Shockwave, or Director dialog box that says
            "Freak out!"?
            > Any known issues?
            LSD is the first thing that comes to my mind. Are you seeing vivid,
            psychedelic colors and are the walls crawling? If so, wait 8 to 10 hours and
            try again.
            OR...
            You might have problems if you forget to upload the .cct files.
            You might have problems if you upload them in ASCII rather than Binary mode.
            I've seen messages where some people accidentally uploaded shortcut links
            (.lnk) to the files rather than the actual files.
            If you haven't actually tried them from a Web server and are testing on a
            local drive, you should be using the dswmedia folder (see the technotes and
            docs for details).
            Mark A. Boyd
            Keep-On-Learnin'
            • 3. Re: .cct files dosnt work on websites =/
              Level 7
              On Mon, 08 May 2006 09:08:47 GMT, mrmille posted in
              > and,
              Did you try selecting a cast member and hitting the delete or backspace key?
              Does that not work for you?
              Mark A. Boyd
              Keep-On-Learnin'
