1 Reply Latest reply on Jan 8, 2007 6:43 AM by rachelmaxim
    What is Flex Data Services?
    ac361 Level 1
      Hi. I'm planning to purchase the Flex Builder 2 to use for displaying richer data controls for ASP.NET 2.0 apps. Will I also need the Flex Data Services? Thanks.
        • 1. Re: What is Flex Data Services?
          rachelmaxim
          It depends on your application. Do you need to push data to the client? If so, then you need FDS. For instance, if you want your end user's screen to update when someone else makes a change, that requires FDS. A lot of the really cool asynchronous features of Flex require FDS, but if you just want a richer interface for what is typically html, then just FlexBuilder may work for you.
