7 Replies Latest reply on Jun 1, 2015 7:05 AM by Brucgovn
    Adobe Creative Cloud email PROBLEM!
    ImagineAlec
      Hey Guys,
      So I have bought the student collcetion yesterday.
      Before I bought it I have tested several products. To test it I had to sing in and create an Adobe ID.
      The problem here is, I just made up an email which doesn't even exist..
      So I bought the collcetion yesterday and downloaded Adobe Creative Cloud again but everytime I want to install something the Creative Cloud pops up and says that I have to verify the email i made up and which doesn't even exist.. Is there a way I can login with my current email with which i bought the collection?
      Thanks for your help.!
      Best regards,
      Alec
        • 1. Re: Adobe Creative Cloud email PROBLEM!
          Brucgovn Adobe Community Professional
          Are you using Windows computer  or Mac?
          Just to confirm again , may I ask whether the email ID using which you had purchased subscription is Valid .
          And the currently logged in user Adobe ID 's email does not exist ?
          • 2. Re: Adobe Creative Cloud email PROBLEM!
            ImagineAlec Level 1
            I am using Windows.
            The ID I'm using is my current ID and it does exist.
            The email and ID i created for the tests does not exist because I just made something up.
            Now when i want to install something creative cloud opens and says that i have to confirm the 'email' that doesnt exist.
            • 3. Re: Adobe Creative Cloud email PROBLEM!
              Quit Creative Cloud desktop application .
              End all Adobe related processes from Task Manager like Creative Cloud , CoreSync. Armsvc.....etc
              Press Windows button (located between Ctrl and Alt buttons) along with R button together at a time , you will get a run command window.
              Type in below command and hit 'Enter' key.
              appdata
              It will open folder named Appdata
              Then navigate to Local>Adobe>OOBE. Open OOBE folder and delete opm.db file.
              Once you had deleted Opm.db file , launch Creative Cloud desktop application and check.
              • 4. Re: Adobe Creative Cloud email PROBLEM!
                ImagineAlec Level 1
                IT WORKED!
                THANK YOU!!!
                • 5. Re: Adobe Creative Cloud email PROBLEM!
                  Glad to hear that
                  You are most welcome.
                  • 6. Re: Adobe Creative Cloud email PROBLEM!
                    ImagineAlec Level 1
                    Hey..
                    something seems not to work again..
                    • 7. Re: Adobe Creative Cloud email PROBLEM!
                      It is the Apps tab Download Error  with Reload Applications option. .
                      Follow below steps :
                      Step 1 :
                      Disable Anti-Virus and Firewall temporarily.
                      If you had installed Security suites like Mcafee , Avg , Norton ....etc make sure to disable their smart firewall.
                      Step 2 :
                      1)Open Control Panel and then click on the option "Network and Internet" .
                      2)Click on Internet options, click on 'Connections' tab.
                      3)In the 'Connections' tab, select 'LAN' settings, you will be able to view the Local area network settings box.
                      4)Check the box-"Automatically Detect Settings" and then "uncheck" all the other check boxes like 'Use automatic configuration script', 'Use a proxy server' , Bypass proxy server' ,then click on ok button .
                      5)Click on "LAN settings" button again , make sure "Automatically Detect Settings" is the only option selected, keep the LAN properties window open.
                      Then launch Adobe Creative Cloud application and try to load Apps list and check.
                      Still same ?? let me know
