4 Replies Latest reply on Jun 2, 2015 8:49 AM by gkaiseril
    I'm using vbScript to populate a fllable PDF file in Serena Small Business Manager (SBM). It is not recognizing the vbCRLF line feed command. Does anyone have a solution? Perhaps using JavaScript?
    linda hurt
      I'm generating an acknowledgement letter from the app. It'll save over 3,000 hours per year. As I don't know JavaScript, I'm hoping to find a solution for vbScript. Here's the code. If someone knows how to translate it into JavaScript, that would be most appreciated too.
      Option Explicit
      DIM sal, fName, mName, lName, suf, city, stateID, zip, FOIAspec, fldList, fldObj, Addr1, Addr2, tmp1, tmp2, ltrAttach
      If Ext.ShellHasProp("Item") Then
      '--Read Fields
      Set fldList = Shell.Item.Fields()
      Set fldObj = fldList.FindField ( "SALUTATION" )
      Call fldObj.GetDisplayValue ( sal )
      Set fldObj = fldList.FindField ( "FOIA_SPECIALIST" )
      Call fldObj.GetDisplayValue ( FOIAspec )
      Call Shell.Item.GetFieldValue("REQUESTOR_S_FIRST_NAME", fName)
      Call Shell.Item.GetFieldValue("REQUESTOR_S_MIDDLE_NAME", mName)
      Call Shell.Item.GetFieldValue("REQUSTOR_S_LAST_NAME", lName)
      Call Shell.Item.GetFieldValue("SUFFIX", suf)
      Call Shell.Item.GetFieldValue("STREET_ADDERSS_1", Addr1)
      Call Shell.Item.GetFieldValue("STREET_ADDRESS_2", Addr2)
      Call Shell.Item.GetFieldValue("CITY", city)
      Set fldObj = fldList.FindField ( "STATE_ABBREVIATION")
      Call fldObj.GetDisplayValue ( stateID )
      Call Shell.Item.GetFieldValue("ZIP_CODE", zip)
      '--Set fldObj = fldList.FindField("LETTER_ATTACHMENTS")
      '--Call fldObj.GetDisplayValue ( ltrAttach )
      vbCRLF = chr(13) & chr(10)
      tmp1 = Addr1
      If len(Addr2) > 0 then
      tmp1 = tmp1&"," & vbCRLF & Addr2
      End if
      tmp1 = tmp1&"," & vbCRLF & city & ", " & mid(stateID,1,2) & " " & zip
      '--Write Fields
      Call Shell.Item.SetFieldValue("REQUESTOR_S_FULL_NAME", fName & " " & mName & " " & lName & " " & suf)
      Call Shell.Item.SetFieldValue("LTR_GREETING", sal & " " & fName &" " & mName & " " & lName & " " & suf&":")
      Call Shell.Item.SetFieldValue("CITY_STATE_ZIP", city&", "&stateID&" "&zip)
      Call Shell.Item.SetFieldValue("FULL_ADDRESS", tmp1)
      Call Shell.Item.SetFieldValue("TEST_ADDR", tmp1)
      '--Call Shell.Item.SetFieldValue("LETTER_ATTACHMENTS", ltrAttach)
      Else
      Call Ext.LogErrorMsg( "TeamScript error: Shell.Item does not exist." )
      End If
