4 Replies Latest reply on Jun 2, 2015 7:24 AM by angieWV
    shortcut problems
    angieWV
      Why do the paragraph styles shortcut keys quit working? This has happened to me twice so I'm guessing some key combination I'm using is inadvertently reseting my shortcuts. Does anyone know the answer?
        • 1. Re: shortcut problems
          OS? What shortcuts stop working?
          • 2. Re: shortcut problems
            angieWV Level 1
            Hi Peter—Windows OS and the shortcuts are those I create for paragraph style sheets. I think it’s something with the control key. For instance, if I hit “cntrl 7” for a paragraph style, I go to home instead of getting the style I’ve assigned to this shortcut.
            Any ideas?
            [personal info removed by moderator]
            • 3. Re: shortcut problems
              Please remove your personal info when you reply by email...
              I don't tend to use shortcuts for styles, but do you see them listed next to the style names?  Have you checked Edit > Keyboard Shortcuts to be sure that you are using the set you expect? Are you using the numbers on the Numpad? Those are reserved for styles and are the only ones that will work for them.
