6 Replies Latest reply on Jun 5, 2015 7:12 AM by BEGINNER_X
    Move Master Page to Destination_Doc and Applied Master for Respective Page
    BEGINNER_X Level 3
      Hi All,
      My Current Request:
      1. i.e., Folder files having around 20 files
      2. All files(20 files) having same master spreads ("A-Master")
      3. Current Script, move all files in the "Destination_Doc", with the same master spreads ("A-Master")
      4. But my Requirement, all are rename in different master spreads.("A-Master", "B-Master", "C-Master" etc....)
      Please refer screenshot.. (Look at both screenshot differences)
      Below Script COding Output:
      Needed Output:
      Final coding:
      #target indesign
      var destination_doc = app.activeDocument;
      var sourceFolder = Folder.selectDialog("Select a folder with source InDesign files.");
      var fileList = sourceFolder.getFiles(/\.indd$/i);
      fileList.sort();
      // run through each file
      for ( var i = 0; i < fileList.length; i++ ) {
          var source_file = fileList[i];
              app.open(source_file);
              var source_doc = app.documents.item(source_file.name);
              var sourcePages = source_doc.spreads.item(0);
              sourcePages.duplicate(LocationOptions.AFTER, source_doc.spreads.item(0));
              sourcePages.move(LocationOptions.AFTER, destination_doc.spreads.item(-1));
              app.activeDocument.close(SaveOptions.NO);
      Thanks in Advance
      Siraj
        • 1. Re: Move Master Page to Destination_Doc and Applied Master for Respective Page
          BEGINNER_X Level 3
          Hi All,
          Is there any possibilites to change Numbers into Alphabets?????
          Kindly look at line 13 in coding.
          fileList.sort();
                  app.activeDocument.masterSpreads.item("A-Master").namePrefix = String(i);   //this is the code
          Screenshot is like as below:
          • 2. Re: Move Master Page to Destination_Doc and Applied Master for Respective Page
            Sajeev Sridharan Level 4
            Try this,
            Change line 13 like below:
            app.activeDocument.masterSpreads.item("A-Master").namePrefix = String.fromCharCode(66 + i);   //this is the code
            • 3. Re: Move Master Page to Destination_Doc and Applied Master for Respective Page
              BEGINNER_X Level 3
              Hi Sajeev(vandy)
              After long time.....
              Your coding is working like a charm...
              A-Z handled rename for only 26 files.
              But for my request is handling more than 50 files...
              Any possibilities, after complete A-Z, rename into "AA-Master", "BB-Master", CC etc.. (or any other better way)
              or
              A1-Master, B2-Master etc...
              • 4. Re: Move Master Page to Destination_Doc and Applied Master for Respective Page
                Try this,
                var j=0, k=1;
                fileList.sort();
                    if(i<25){app.activeDocument.masterSpreads.item("A-Master").namePrefix = String.fromCharCode(66 + i);}
                    else{j++; app.activeDocument.masterSpreads.item("A-Master").namePrefix = String.fromCharCode(64+j) + String(k);if(j==26){j=0; k++;}}
                • 5. Re: Move Master Page to Destination_Doc and Applied Master for Respective Page
                  BEGINNER_X Level 3
                  Hi Sajeev,
                  Sorry for the delayed response ...
                  Finalize Request is, after complete A-Z, rename into "AA-Master", "BB-Master", CC etc.. (after that AAA, BBB etc...)
                  Using Your code, I modified as below:
                  (Is there any better coding??) (so handle any number of files)
                  var x=0, y=1;
                  var z=0;
                  if(k<26){
                      app.activeDocument.masterSpreads.item("A-Master").namePrefix = String.fromCharCode(65 + k);
                  else if(k>25 && k<52){
                      x++;
                         app.activeDocument.masterSpreads.item("A-Master").namePrefix = String.fromCharCode(64+x) + String.fromCharCode(64+x);
                  else if(k>51 && k<78){
                  z++;
                     app.activeDocument.masterSpreads.item("A-Master").namePrefix = String.fromCharCode(64+z) + String.fromCharCode(64+z) + String.fromCharCode(64+z);
                  //etc..
                  Thanks in Advance
