3 Replies Latest reply on Jun 7, 2015 11:33 AM by S Hopkins
    Auto page numbering
    Level 1
      I having more than hundred application files. I need to reset the page number for all application file based on sequence.
      Example first chapter staring page no 1 and end page no 10
      I need to change the second chapter starting number 11
      Is this possible to update the page number via scripting
        • 1. Re: Auto page numbering
          S Hopkins Adobe Community Professional
          In reference to your question about auto page numbering:
          Yes, you can change page numbering using scripting. You can also change the auto page numbering manually from the pages panel: From the list of pages in the document, select the page at which you want to change numbering. Then, from the pages panel's contextual menu (little down arrow at top right) select numbering and section options. This dialog is pretty self explanatory. Check Start Section, and Start Page Numbering at. Enter the number for the page.
          If you combine your documents into a book (File > New > Book), you can update the page numbering from the Book's contextual menu. Select Update Numbering, then Update Page and Section Numbers.
          With scripting the process is similar: you can create sections and indicate where the section will start, what the page number will start with, and so on. The following is for AppleScript, ExtendScript will be similar.
          tell application "Adobe InDesign CC 2014"
             set docRef to document 1
             tell docRef
                set pageRef to page 1 of spread 1
                set sectionCount to count of sections
                if sectionCount > 0 then
                   tell section 1
                      set continue numbering to false
                     set page start to pageRef
                     set page number start to 1
                  end tell
                else --if no sections exist
                   make section with properties {name:"First", page number style:arabic, continue numbering:false, page number start:1, page start:pageRef, marker:"", length:8, section prefix:"", include section prefix:false}
                end if
             end tell
          end tell
          Hope this is what you needed.
          • 2. Re: Auto page numbering
            Level 1
            I am having windows machine. Is this possible via java scripting.
            • 3. Re: Auto page numbering
              Sorry for delay in reply. Yes, you can definitely do this with ExtendScript. In this example, a second section is created in the same document. Try this with a document having 8 pages.
              var docRef = app.activeDocument;
              var pageRef = docRef.spreads.item(0).pages.item(0);
              var sectionCount = docRef.sections.count();
              var sectionProps = {pageNumberStyle:"arabic", continueNumbering:false, pageNumberStart:1, marker:"", sectionPrefix:"", includeSectionPrefix:false}
              if (sectionCount > 0) {
                  var section1 = docRef.sections.item(0);
                   section1.continueNumbering = false;
                   section1.pageStart = pageRef;
                   section1.pageNumberStart = 1;
              } else {
                  section1 = docRef.sections.add(pageRef);
                  section1.name = "Section1";
                  section1.properties = sectionProps;
              if (docRef.sections.count() == 1) {
                 sectPageRef = docRef.spreads.item(5).pages.item(0);
                 var section2 = docRef.sections.add(sectPageRef);
                 section2.name = "Section2";
                 section2.properties = sectionProps;
