10 Replies Latest reply on Jun 19, 2015 11:15 AM by ldallara
    LR 6.0.1 Crashing
    ldallara
      Any ideas why Lighroom 6.0.1 keeps crashing ?
        • 1. Re: LR 6.0.1 Crashing
          GautamBahl Adobe Employee
          Hi Louis,
          We would require a lot more information in order to help you out.
          Are you using Windows or Mac?
          What is the error message when it crashes?
          Which graphic card are you using?
          Thank you for posting on Adobe Forums.
          • 2. Re: LR 6.0.1 Crashing
            ldallara Level 1
            Hi;
            OK Windows 7 with SP 1 installed
            Graphics card AMD Radeon HD 6800 series Extended Desktop with 2 monitors ( Updated to Latest Drivers)
            Corrupts the catalog and cannot repair it on next try.
            I'll provide more infor on the next crash.
            • 3. Re: LR 6.0.1 Crashing
              It seems that the first line of defense with this problem would be to disable GPU acceleration in your Lightroom preferences.
              • 4. Re: LR 6.0.1 Crashing
                Hi Louis,
                There has been issues reported with AMD graphic card with Lightroom.
                Please open device manager and right click on the AMD graphic card and choose browse my computer and then choose update driver software, choose let me pick from a list of drivers.
                Choose standard VGA or Microsoft basic display adaptor. Then launch Lightroom and click on edit>Preferences>performance and uncheck the graphic processor.
                Update your display drivers automatically now and launch Lightroom again and check.
                • 5. Re: LR 6.0.1 Crashing
                  F. McLion Adobe Community Professional & MVP
                  Before switching to a Standard MS VGA driver I'd definitely just deactivating the GPU acceleration: Lightroom Graphics Processor Acceleration (GPU) Troubleshooting & FAQ
                  • 6. Re: LR 6.0.1 Crashing
                    ldallara Level 1
                    Already update video card drivers
                    LR 5 worked fine.... so now it doesn't support GPU,
                    Using standard VGA is unacceptable.
                    I'll go back to LR 5 I don't need face rec.
                    • 7. Re: LR 6.0.1 Crashing
                      ldallara Level 1
                      Graphics Processor Info:
                      Check OpenGL support: Failed
                      Vendor: ATI Technologies Inc.
                      Version: 3.3.11762 Core Profile Context
                      Renderer: AMD Radeon HD 6800 Series
                      LanguageVersion: 4.20
                      GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS (actual = 32, minimum = 48)
                      Rolled back driver per Instructions.
                      Unchecked box for GPU
                      • 8. Re: LR 6.0.1 Crashing
                        Your card is not supported. Forget the tip to switch to standard VGA driver given by GautamBahl and leave your current driver in place. Simply un-check the GPU acceleration in LR6 and restart LR6. This should do the trick - there's no need to go back to LR5.
                        • 9. Re: LR 6.0.1 Crashing
                          Hi Louis,
                          As you can see from the report OpenGL Support:failed, Lightroom 5 is working fine on your machine as it does not depend on your graphic card.
                          This feature was introduced in Lightroom CC. There has been issues reported with AMD graphic card and we are working on it.
                          For the time being i would recommend to uncheck the graphic processor option. The standard VGA option was suggested, incase you are not able to get to the interface of Lightroom CC.
                          If you are able to launch Lightroom CC, then simply go to preferences>performance and uncheck the graphic processor and re launch Lightroom CC.
                          • 10. Re: LR 6.0.1 Crashing
                            ldallara Level 1
                            FYI;  i don't use LRCC, i use the standalone both LR and PS.
                            After unchecking box on the graphic processor option, nothing changed. Still random crashes.
                            Finally able to save on exit.
                            I am unable to do optimize database or check it. Those process corrupt it.
                            I just upgraded to 6.1.
                            Not sure if anything has changed,
                            I wonder why my AMD graphic card using the graphic processor option works and doesn't crash in PS6  ???
                            I am looking at Graphics Card and need to find out what one will work with my MB.
                            Lou
