2 Replies Latest reply on Mar 17, 2017 2:19 PM by surbhis10222950
    NetConnection.Call.Failed: HTTP: Status 404: url: 'http://localhost:8080/WebContent/messagebroker/amf''
    mygush
      Hello everybody,
      I have traveled the forum but I still have not found a solution to my problem:
      I recently installed Flash Builder 4.7 and I want to run my web application with java / Flex / BlazeDS.
      I use the 4.0.1.21287 version of BlazeDS with tomcat 7.
      It was working fine with Flex Builder 3 and tomcat 6.
      I seem to have set everything correctly but I always this error :
      Here are the settings in my services-config.xml :
      <?xml version="1.0" encoding="UTF-8"?>
      <services-config>
          <services>
              <service-include file-path="remoting-config.xml" />
              <service-include file-path="proxy-config.xml" />
              <service-include file-path="messaging-config.xml" />
          </services>
          <security>
              <login-command class="flex.messaging.security.TomcatLoginCommand" server="Tomcat"/>
          </security>
          <channels>
              <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
                  <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
              </channel-definition>
              <channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel">
                  <endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker/amfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/>
                  <properties>
                      <add-no-cache-headers>false</add-no-cache-headers>
                  </properties>
              <channel-definition id="my-polling-amf" class="mx.messaging.channels.AMFChannel">
                  <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolling" class="flex.messaging.endpoints.AMFEndpoint"/>
                  <properties>
                      <polling-enabled>true</polling-enabled>
                      <polling-interval-seconds>4</polling-interval-seconds>
                  </properties>
          </channels>
          <logging>
              <target class="flex.messaging.log.ConsoleTarget" level="Error">
                  <properties>
                      <prefix>[BlazeDS] </prefix>
                      <includeDate>false</includeDate>
                      <includeTime>false</includeTime>
                      <includeLevel>false</includeLevel>
                      <includeCategory>false</includeCategory>
                  </properties>
                  <filters>
                      <pattern>Endpoint.*</pattern>
                      <pattern>Service.*</pattern>
                      <pattern>Configuration</pattern>
                  </filters>
              </target>
          </logging>
          <system>
              <redeploy>
                  <enabled>false</enabled>
                  <watch-interval>20</watch-interval>
                  <watch-file>{context.root}/WEB-INF/flex/services-config.xml</watch-file>
                  <watch-file>{context.root}/WEB-INF/flex/proxy-config.xml</watch-file>
                  <watch-file>{context.root}/WEB-INF/flex/remoting-config.xml</watch-file>
                  <watch-file>{context.root}/WEB-INF/flex/messaging-config.xml</watch-file>
                  <watch-file>{context.root}/WEB-INF/flex/data-management-config.xml</watch-file>
                  <touch-file>{context.root}/WEB-INF/web.xml</touch-file>
              </redeploy>
          </system>
      </services-config>
      Does anyone can help me on this ?
      Thanks in advance for your help!
