2 Replies Latest reply on Jun 4, 2015 9:46 AM by gkaiseril
    How to get date in a text field in dd-mmm-yyyy format in adobe acrobat?
    Alex Doubts Level 1
      I am able to get the current date in dd-mmm-yyyy fromat. But not so in the text field.
      var k=util.printd("dd-mmm-yyyy", new Date()); //12-Jun-2015
      But below code is not working
      var k=util.printd("dd-mmm-yyyy",getField("txtDate").value;
      Please update with a solution at the earliest.
        • 1. Re: How to get date in a text field in dd-mmm-yyyy format in adobe acrobat?
          First of all, you're missing the closing parenthesis in your code.
          Also, the second parameter of the printd method needs to be a Date object. The value of a field is usually a string, so it's not clear what you're trying to do, really. What is the value of that field? A date in a different format? Something else?
          • 2. Re: How to get date in a text field in dd-mmm-yyyy format in adobe acrobat?
            When I try your code in the JavaScript console, I get the following JavaScript console error:
            TypeError: Invalid argument type.
            Util.printd:1:Console undefined:Exec
            ===> Parameter oDate.
            undefined
            Which means one of the 2 required parameters for the util.printd method is an invalid data type. The format is a string but the 2nd parameter is an object not a string.
            You might want to look at the MDN JavaScript Reference and the Acrobat JS API Reference for more information about the new Date()util.printd() , and util.scand().
            The new Date():
            "If no arguments are provided, the constructor creates a JavaScript Date object for the current date and time according to system settings."
            new Date() creates a date object not a string or number value.
            util.printd() formats a date date object to a string value.
            util.scand() converts a string to a date object.
            To reformat a date string form one format to another one must first create a date object and then create the string with desired format from the date object.
            var cOldFormat = "dd/mm/yyyy"
            var cNewFormat = "dd-mmm-yyyy";
            var cDate = getField("txtDate").value;
            var oDate = util.scand(cOldFormat, cDate)
            var k=util.printd(cNewFormat, oDate);
            Date arithmetic
            There is a wealth of information in the reference material. It is not always easy to read but once one understands the information it is invaluable.
