6 Replies Latest reply on Jun 4, 2015 9:31 AM by Colin Holgate
    help pls !!!
    salemb20068047
      hi guy i have script that it is AS 0.3 camera movement action script .... i want the equivalent code for AS 1.0      BTW guys i am using micromedia flash mx
      this is the code
      function camControl():Void { parentColor.setTransform(camColor.getTransform()); var scaleX:Number = sX/this._width; var scaleY:Number = sY/this._height; _parent._x = cX-(this._x*scaleX); _parent._y = cY-(this._y*scaleY); _parent._xscale = 100*scaleX; _parent._yscale = 100*scaleY; } function resetStage():Void { var resetTrans OBJECT = {ra:100, rb:0, ga:100, gb:0, ba:100, bb:0, aa:100, ab:0}; parentColor.setTransform(resetTrans); _parent._xscale = 100; _parent._yscale = 100; _parent._x = 0; _parent._y = 0; } // make frame invisible this._visible = false; // Capture stage parameters var oldMode:String = Stage.scaleMode; Stage.scaleMode = "exactFit"; var cX:Number = Stage.width/2; var cY:Number = Stage.height/2; var sX:Number = Stage.width; var sY:Number = Stage.height; Stage.scaleMode = oldMode; // create color instances for color // transforms (if any). var camColor:Color = new Color(this); var parentColor:Color = new Color(_parent); // Make the stage move so that the // v-cam is centered on the // viewport every frame this.onEnterFrame = camControl; // Make an explicit call to the camControl // function to make sure it also runs on the // first frame. camControl(); // If the v-cam is ever removed (unloaded) // the stage, return the stage to the default // settings. this.onUnload = resetStage;
