0 Replies Latest reply on Jun 4, 2015 5:23 AM by tbrglnd
    Batch update links in several formats
    tbrglnd
      I've got about 30 indd documents all using the same image folder called 'Lowres'. These images are updated once in a while to new version but with the same filename so I have to open each file and update links and save. I've solved this by using a batch&convert script, choose export JPGs and select 'update links before exporting' and 'save documents on closing'. This is great as long as the images are updated and not moved.
      The thing is, when I've received final images I would like to rename the 'Lowres' folder to 'Highres' or 'Final' or something like that to know that these are actual final images and no changes will be made from that point. Is there a way to do that without having to open all the files and 'relink to folder'?
      Thomas
