• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Flash background updater not updating
New Here ,
Jun 04, 2015 Jun 04, 2015
I've setup an internal Flash server to do updates in my corporate network but seem to be having issues getting the clients to get the updates.  My mms.cfg file contains the following lines:
AutoUpdateDisable=0
SilentAutoUpdateEnable=1
SilentAutoUpdateServerDomain=updateserver.internaldomain.com
I have a Self signed cert in place on the hosting web server IIS 7.5 and also in the Trusted root certificate store (local machine).  I can browse the update server and pull any of the xml files via http and https with no certificate errors.
When I manually execute the "FlashPlayerUpdateService.exe" file with admin privs I see the following lines in the flashinstall.log
[info] 1628 servernameinmmsfile
[info] 1629 servernameinmmsfile
[info] 1614
[info] 1615
[info] 1618
[info] 1619 1063
[error] 1222 1060
Also I'm running wireshark and I see no connections go out to the update server when executing the "FlashPlayerUpdateService"
Where am I going wrong?
Views
1.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Hi tomtaylorprecash,
Executing the service using 'FlashPlayerUpdateService.exe' should work.  The error 1222 indicates opening the service failed.  The number next to it is the corresponding Microsoft error code, which in this case is ERROR_SERVICE_DOES_NOT_EXIST - The specified service doe not exist as an installed service.
There are actually two components of the background update service: the service itself and a scheduled task.  Since the error is indicating that the Service is missing, let's verify that the Service, and the Schedule Task, exist on the impacted system.  Please do the following:
  1. Launch the Services panel
  2. Look for Adobe Flash Player Update Service
  3. Launch the Task Scheduler
  4. In the Task Schedule Library look for Adobe Flash Player Updater
If they are there, run the background update from both the Service (right-click > Start) and the Scheduled Task (right-Click > Run).
Please provide the entire contents of the FlashInstall.log file from the impacted system (obtained after running the Service and Task if they are present).  The file may be fairly large to post here.  You can upload the file using the instructions here, How to share a document
Thank you.
Maria
Votes
Translate
Translate
Report
Report
New Here ,
Jun 05, 2015 Jun 05, 2015
Hi Maria, I've checked and the service does exist however the scheduled task does not exist.  The installed version 15.0.0.152.  When I look at the service itself the executable it is calling is armsvc.exe
Votes
Translate
Translate
Report
Report
New Here ,
So I exported the Scheduled task from a machine that has the current version of Flash player and imported it into the machine with version 15.0.0.152.  So I verified the armsvc.exe service was running and then right clicked on the scheduled task and told it to run.  I did this twice and attached is the log file.
2015-6-5+15-9-38.569 [info] 1628 bs-pdxutility00.xxx.xxx.com
2015-6-5+15-9-38.631 [info] 1629 bs-pdxutility00.xxx.xxx.com
2015-6-5+15-9-38.693 [info] 1614
2015-6-5+15-9-38.756 [info] 1615
2015-6-5+15-9-38.818 [info] 1618
2015-6-5+15-9-38.881 [info] 1619 1063
2015-6-5+15-9-38.881 [error] 1222 1060
2015-6-5+15-10-52.779 [info] 1628 bs-pdxutility00.xxx.xxx.com
2015-6-5+15-10-52.794 [info] 1629 bs-pdxutility00.xxx.xxx.com
2015-6-5+15-10-52.794 [info] 1614
2015-6-5+15-10-52.794 [info] 1615
2015-6-5+15-10-52.794 [info] 1618
2015-6-5+15-10-52.794 [info] 1619 1063
2015-6-5+15-10-52.794 [error] 1222 1060
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi TomTaylorPrecash,
armsvc.exe is a Reader process.  The Adobe Acrobat Update Service is the service that executes this process.
The Adobe Flash Player Update Service executes FlashPlayerUpdateService.exe.
This seems to be a corrupt installation, since the required Task and Service do not exist.  Please do the following:
  1. Post a screenshot of the /sau directory (expanded to show all contents) on your server. See How to post a screenshot in the forum
  2. Download the latest uninstaller from the Uninstall Flash Player | Windows page and uninstall Flash Player from the impacted system
  3. Re-install Flash Player
  4. Post here the portion of the log file that includes the uninstall and install.  If this is a 64-bit OS, provide the log file contents from both\Windows\System32\Macromed\Flash and \Windows\SysWow64\Macromed\Flash.  The beginning of the uninstall will look similar to the following:
               =O====== M/17.0.0.188 2015-06-04+15-52-40.171 ========
               0000 00000010 "\\Desktop_path\uninstall_flash_player.exe" -force
Thank you.
Maria
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 19, 2015 Nov 19, 2015
I have just the same issue on some clients.
2015-11-19+11-1-0.265 [info] 1628 fp-update.domain.local
2015-11-19+11-1-0.312 [info] 1629 fp-update.domain.local
2015-11-19+11-1-0.312 [info] 1614
2015-11-19+11-1-0.327 [info] 1615
2015-11-19+11-1-0.327 [info] 1618
2015-11-19+11-1-0.327 [info] 1619 1063
2015-11-19+11-1-0.327 [error] 1222 1060
The problem appeared after migration of the update server from IIS on Win2012 server to Nginx on Ubuntu Server.
The name and IP address of the server has changed as well, but we replaced mms.cfg with a new one.
Most of the clients continue to update from the new server as they did from the old one. But some (including my computer and several colleagues') don't.
What can be the reason and how can I fix it without reinstalling FlashPlayer?
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi Petr.Egorov,
Can you verify if the Background Update service exists on the client machine?  In Control Panel\All Control Panel Items\Administrative Tools > Services look for 'Adobe Flash Player Update Service'
Maria
Votes
Translate
Translate
Report
Report
Explorer ,
No, for some reason it does not exist. But there's a task in Task Scheduler that triggers the same executable as the service does.
Is there a requirement to have both service and task for update to work?
Can I create the service manually?
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Nov 30, 2015 Nov 30, 2015
LATEST
Hi Petr.Egorov,
Sorry for the late reply.
Yes, both the task and the service need to exist for the background update to work.  Can you provide the entire install log file for an impacted system?  You can upload the file to cloud.acrobat.com using the instructions How to share a document or a file sharing service of your choice.  Include the link to the uploaded file in your reply.
Maria
Votes
Translate
Translate
Report
Report
