2 Replies Latest reply on Jun 4, 2015 11:39 AM by Rodney1947
    What does the "snap" feature do?
    Rodney1947
      I am using v.9 and was wondering what the "snap" feature does.  I can't find any explanation of it anywhere.
        • 1. Re: What does the "snap" feature do?
          A.T. Romano Level 7
          Rodney
          This is an excerpt from an Adobe document which should apply to Premiere Elements in general
          Arranging clips in the Expert view timeline
          Align clips by using the Snap option
          The Snap option, which is enabled by default, makes it easier to align clips with each other or with particular points in time. You can move a clip with the Snap option selected. The clip automatically aligns with the edge of another clip, a marker, the start and end of the time ruler, or the current‑time indicator.
          Snapping also helps ensure that you don’t inadvertently perform an insert or overlay edit when dragging. As you drag clips, a pop‑up window displays the distance, in frames, that you have moved them. A negative number indicates you’ve moved them toward the beginning of the movie.
            Choose Timeline > Snap. A check mark indicates that the option is enabled
          ATR
