3 Replies Latest reply on Apr 24, 2018 5:40 PM by mjmbkk
    Merge Folders in Lightroom
    abigailb71076034 Level 1
      My computer has two hard drives that I use to store  photos.  My more recent files (of the last month or so) are stored on my computer's primary drive, and everything that is older is generally on the secondary drive.  When I import new files, they are set to be saved in folders and subfolders based on year, month and day (2015\2015-01\2015-01-20).
      Most of my photos are from my DSLR and are uploaded on a pretty regular basis, and there may be only a handful of separate folders created.  When I import photos from my phone, however, the files are as old as 2 years.  This causes a number of new folders to be created on my primary hard drive that just have a handful of photos each. Since most of these should be stored on the secondary drive due to their age alone, I would like to merge any new folders created due to the recent import with the folders I have already moved to the secondary drive .  If I try to click and drag the folders, Lighroom tells me 'A folder named "XX" already exists at this location'.
      I can click and drag the actual photos, but that will be much more time consuming due to the number of folders.
      Is there a good way to merge folders within the catalog, from one location to another (i.e. move folder "2015-03-02" from hard drive A and merge with folder "2015-03-02" that already exists on hard drive B)?
        • 1. Re: Merge Folders in Lightroom
          THG_BO Level 4
          Hello,
          this is not possible. You have to copy the files to the folders if they already exist. But you can choose the secondary drive as a target during import. An even better - you can save your import settings as a preset. Define two presets e.g. "new images to 1st drvie", "old images to 2nd drive" an choose the correct one during import.
          • 2. Re: Merge Folders in Lightroom
            ManiacJoe Adobe Community Professional
            If you have not already imported them to the "other" hard drive, importing them to the desired drive would be your best bet.
            If the photos are already on two drives, you can merge them but not entirely within LR.
            First you would need to use Explorer/Finder to merge the to groups of files into one directory tree on the one drive.
            Then you would go into LR, Library module, Folders panel, and "relocate" the moved directories.
            Test this with a small set of files to make sure it works the way you want it to.
            • 3. Re: Merge Folders in Lightroom
              mjmbkk Level 1
              I just discovered something. In the left panel, in the folders section is the original drive letter, grayed out. All of the photos are there, no image, but the metadata, and keywords with the "!" in the upper right corner. When I right click  on Find Missing Folder, I go to the current drive letter where everything is. Remember, its the same drive, only the letter has been changed. The folders are organized by year.
              When i click on Select Folder, same name/year as it was before the drive letter was changed, I get the following message: The selected folder or one  of its sub folders is already in LR. Do you want to combine these folders?
              The sub folders are months and days.
              If I select Merge, will the keywords stay with all the images when I merge the folders?
