3 Replies Latest reply on Jun 8, 2015 6:41 AM by TᴀW
    How to change this script, increase one case that is "change each word'first letter to capital"
    喜狼_edny Level 1
      I want change each word's first letter to capital.
      Help me~
      Thank you very much!
      -----------------------------------------------------Below,there is already script.------------------------------------------------------------
      //BS”D
      //ToggleCase
      //An InDesign CS4 script (c) Ariel Walden, 2011
      //Freebie script from http://www.FreelanceBookDesign.com
      try{
      mySelection = app.selection[0];
      if (mySelection instanceof InsertionPoint){
      if(mySelection.words[0].isValid) mySelection = mySelection.words[0];
      else{
      myIndex = mySelection.index;
      if (myIndex < mySelection.parent.insertionPoints[-1].index && mySelection.parent.insertionPoints[myIndex+1].words[0].isValid) mySelection = mySelection.parent.insertionPoints[myIndex+1].words[0];
      else {
      mySelection = mySelection.parent.insertionPoints[myIndex-1].words[0];
      myText = mySelection.contents;
      if (myText != myText.toUpperCase() && myText != myText.toLowerCase()) mySelection.changecase(ChangecaseMode.UPPERCASE);
      if (myText == myText.toUpperCase()) mySelection.changecase(ChangecaseMode.LOWERCASE);
      if (myText == myText.toLowerCase()) mySelection.changecase(ChangecaseMode.SENTENCECASE);
      if (myText == myText.toSentenceCase()) mySelection.changecase(ChangecaseMode.TITLECASE);
      if (myText == mySelection.contents) mySelection.changecase(ChangecaseMode.UPPERCASE); //necessary because if lowercase letter in middle of word selected, changing to titlecase does nothing.
      catch(f){}
        • 1. Re: How to change this script, increase one case that is "change each word'first letter to capital"
          TᴀW Adobe Community Professional & MVP
          You want Title Case? So just run the script again!
          The point of the script is to cycle (not toggle!) the current selection
          through three capitalization modes -- it makes it easy to switch the
          select word to all caps, or title case, or lower case, like Word's
          built-in function. The script works best if you assign a keyboard
          shortcut to it -- just select your text, and keep hitting the shortcut
          until you get the capitalization you want.
          Hope that explanation helps. What I'm saying is that what you appear to
          be asking is already the way the script works!
          • 2. Re: How to change this script, increase one case that is "change each word'first letter to capital"
            Hold on! I just noticied that what you've posted is modified version of my script -- and, almost inevitably -- the modification broke it! To make it work as originally intended -- delete the line with the SENTENCE CASE option, so the original script should look like this:
            //BS"D
            //ToggleCase
            //Freebie script from www.Id-Extras.com
            try{
              else{
              if (mySelection.parent.insertionPoints[myIndex+1].words[0].isValid) mySelection = mySelection.parent.insertionPoints[myIndex+1].words[0];
              else {
              if (myText == myText.toLowerCase()) mySelection.changecase(ChangecaseMode.TITLECASE);
            catch(f){}
