2 Replies Latest reply on Jun 9, 2015 8:34 AM by Vamitul
    merge multiple indd docs into one without any dialog (cs6)
    kajzica Level 1
      I need script which can merge/combine multiple indesign files into one indd doc, but without any dialog like missing fonts etc?
      I simply cant manually move pages from doc to doc....
      tnx
      i have this script but have error
      // DESCRIPTION: Mass combine a bunch of indd files into one.
      // 6 July 2013
      // INSTRUCTIONS
      // Put all the files you want to combine into one document in a folder, named in the order
      // you want them to appear in the book (e.g. "001.indd", "002.indd", etc. or something) so
      // they appear correctly when sorted by name in finder/explorer.
      #target indesign
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
      // set the destination document as the active document.
      var destination_doc = app.activeDocument;
      // select the source folder
      var sourceFolder = Folder.selectDialog("Select a folder with source InDesign files.");
      // if we're not in the source folder, stop running the script.
      if ( !sourceFolder ) {
        exit(0);
      // set file list and run through each file. Sorting them alphanumerically.
      var fileList = sourceFolder.getFiles();
      fileList.sort();
      // run through each file
      for ( var i = 0; i < fileList.length; i++ ) {
        var source_file = fileList[i];
        // making sure it's an indesign file...
        if ( source_file instanceof File && source_file.name.match(/\.indd$/i)) {
        app.open(source_file);
        var source_doc = app.documents.item(source_file.name);
        var sourcePages = source_doc.pages.item(0);
        // break the master page items so they can be moved onto the new document.
        var masterItems = sourcePages.masterPageItems;
        if ( masterItems.length > 0 ) {
        for ( var j=0; j<masterItems.length; j++ ) {
        masterItems[j].override(sourcePages);
        // removing the applied master (this can mess up some files if not done)
        sourcePages.appliedMaster=null;
        // duplicating it in the original file (due to errors) and them moving it to
        // the destination document.
        sourcePages.duplicate(LocationOptions.AFTER, source_doc.pages.item(0));
        sourcePages.move(LocationOptions.AFTER, destination_doc.pages.item(-1));
        // closes the file that was opened without saving (to avoid memory problems)
        app.activeDocument.close(SaveOptions.NO);
        • 1. Re: merge multiple indd docs into one without any dialog (cs6)
          Daniel Sterchi Adobe Community Professional
          Hi kajzica
          The error which is seen on your screenshot is not just a missing font. It is a real error which prevents the script from going on.
          I guess that there is a problem with one of the files.
          if you open a file from within InDesign it then will become the activeDocument. So you may write
          var scource_doc = app.activeDocument;
          instead of
          But that is not the problem.
          Every InDesign file has at least one page. So there must be an other error. I guess with one of the files in your array.
          kind regards
          Daniel (from Switzerland)
          • 2. Re: merge multiple indd docs into one without any dialog (cs6)
            Vamitul Level 4
            that error is created by this wierd onstruct:
            replace with:
                 var source_doc=app.open(source_file);
            The
            app.scriptPreferences.userInteractionLevel=UserInteractionLevels.NEVER_INTERACT
            should have taken care of missing fonts dialogs and stuff like that, unfortunately it seems to give strange results with the new TypeKit dialog.
