3 Replies Latest reply on Jun 9, 2015 10:50 AM by kglad
    Quiz codes
    maluchrider
      Good morning everyone!
      I am a beginning Flash CS5 user and I was wondering if anybody could help me. I succeeded in making a very simple quiz in Action Script 2 and wanted to develop my abilities: I've been struggling to add following features to my quiz: e.g. a 15-second timer on every question frame ( I can only produce a timer that lasts the whole quiz and does not reset) and a life-counting device (i.e. if you get the answer wrong three times, you lose, whereas if you simply make a mistake you get a chance to re-answer the question). Thank you very much in advance, I underline that I am a complete beginner and therefore I kindly ask for very straightforward help! Thank you again
        • 1. Re: Quiz codes
          for an as2 timer, you can use a setTimeout function.
          // initialize once
          var timerTO:Number;
          //when a question is presented:
          clearTimeout(timerTO);
          timerTO = setTimeout(timerF,15000);
          function timerF():Void{
          // 15 seconds is up
          function questionAnsweredF():Void{
          // stop the timer
          and for your life-counting use a variable. eg,
          var lives:Number=3;
          //whenever a question is answered incorrect decrement lives and check it it's == 0.
          • 2. Re: Quiz codes
            maluchrider Level 1
            Thank you for the answer, but I haven't fully understood (sorry I am a big newbie). How do I tag the questions wrong and correct? I used to convert them into buttons and the right one allowed the player to proceed to the next frame.
            • 3. Re: Quiz codes
              add listeners to your buttons.  the one that's associated with the correct answer should call a correct function (eg, correctF) and the others should call an incorrect function (eg, incorrectF).
              eg, you could use:
              function correctF(e:MouseEvent):void{
              // increment a score
              // advance to the next question
              function incorrectF(e:MouseEvent):void{
              lives--;
              if(lives==0){
              gameoverF();
              } else {
              function gameoverF():void{
              //do whatever
