1 Reply Latest reply on Jun 9, 2015 11:33 AM by JeepyCote
    Why Create Merge document button doesn't work
    JeepyCote
      I click on it, sometime I can see it can how start to work, but it doesn't create a new document...
      I am using this fonction regulary.
      I have just rebooted. No difference, except I have the time to see the box "merging documents" going.
        • 1. Re: Why Create Merge document button doesn't work
          JeepyCote Level 1
          A bug. I have saved as IDML then re-imported... Worked a bit but there is a very particular bug. When you have inserted variables in various layers (FRench, english) you can't merge document if you are not on a particular layout while clicking on merge...
          Weird. I had to put all the variable on the same layer, and have two different template, one for the english variables and another for the french ones. So 2 different merge files instead of one (and playing with the layers to export)
