3 Replies Latest reply on Jun 9, 2015 9:37 PM by A.T. Romano
    HOW DO I BURN   TO A DVD   JUST PART OF A MOVIE..
    TONY2ND2NONE
      I like the program    i TOOK  A VIDEO OF A WEEDING AND I JUST WANT TO BURN part  of the movie TO A DVD   THE CHURCH PART .  ..  I MOVED THE CLIPS TO THE LEFT AND NOW THEY ARE A SMALL LINE  IN THE TIME LINE.. HOW DO I TAKE AND ONLY BURN THAT PART..
        I will buy   adobe 13   if i can learn this adob elemnt 12
                                tony carrubba
           440 781 8883
        • 1. Re: HOW DO I BURN   TO A DVD   JUST PART OF A MOVIE..
          A.T. Romano Level 7
          tonyc
          What version of Premiere Elements do you now have? And, on what computer operating system is it running?
          Using Publish+Share/Disc/DVD disc, you cannot burn to disc part of your Timeline content as you can in many instances in the export to file saved to the computer hard drive...Publish+Share/Computer/. In the file situation, the keys are setting the Work Bar Area gray tabs to span the segment of interest coupled with enabling "Share Work Area Bar Only" in the export settings.
          What you might consider is this...make a copy of the whole project and edit the copy so that the copy contains parts and features related to a specific part of the wedding. Then burn that Timeline content to disc. See File Menu/Save a Copy.
          Does that work for you?
          ATR
          Add On..You may be able to achieve your goal by going through the Timeline content and removing the check mark next to Enable for the clips that you do not want...depends on location of the files to go. I will double check that and let you know.
          Add On to Add On..The disabling of the Enable option should be expected to work for you depending on the location of the files. Please let us know if any of the above works for you. I still think it safer to work from the copy rather than run the risk of disturbing an existing Timeline depending on the location of the files to go.
          • 2. Re: HOW DO I BURN   TO A DVD   JUST PART OF A MOVIE..
            TONY2ND2NONE Level 1
            WIN 7   AND APE12
                     If I get APE 13.   Will this be easer to perfrom
            Nick Mayer & Marshall  Ford
            Drivability Performance Specialist
            Tool Box 440 995 4393
            Shop 440  449 1000 ext 418
            Cell 440 781 8883
            TONY  CARRUBBA
            In a message dated 6/9/2015 12:58:13 P.M. Eastern Daylight Time,
            forums_noreply@adobe.com writes:
            created by A.T. Romano (https://forums.adobe.com/people/A.T.+Romano)  in
            Premiere Elements - View the full  discussion
            (https://forums.adobe.com/message/7623831#7623831)
            • 3. Re: HOW DO I BURN   TO A DVD   JUST PART OF A MOVIE..
              A.T. Romano Level 7
              tonyc
              Thanks for the reply.
              No.In this regard, Premiere Elements 11, 12/12.1, and 13/13.1 offerings are the same.
              Please let me know if you are OK with the carrying out details that I have already provided. We can discuss them further if they need clarification.
              I will revisit your thread in the morning.
              Thanks for the follow up.
              ATR
