1 Reply Latest reply on May 9, 2006 12:07 PM by Newsgroup_User
    Pop-up Menu Behavior Causes Generates Error Message
    Roger_D_T
      I'm using DW from a Studio MX install. I'm trying to add a flyout menu (NO SERMONS PLEASE). When I add the pop-up menu behavior I get the following error message:
      While executing applyBehavior in Show Pop-Up Menu.htm, the following JavaScript error(s) occurred:
      At line 247 of file "C:/Program Files\Macromedia\Dreamweaver MX 2004\Configuration\Behaviors\Actions\Show Pop-up Munu.js":
      TypeError: thehead.innerHTML has no properties
      The action will not be added to your document.
      I have a version of Studio 8 on a different PC and am able to add the pop-up menu behavior just fine. I've uninstalled and reinstalled DW MX via the control panel, but suspect that didn't remove all of the related files.
      Anyway, I'm looking for ideas on the cause, how to fix it, and/or how to completely de-install Macromedia DW MX.
      TIA,
      Roger
        • 1. Re: Pop-up Menu Behavior Causes Generates Error Message
          Level 7
          You can try this simple fix -
          Quit DW.
          Find this file -
          C:\Documents and Settings\<username>\Application Data\Macromedia\Dreamweaver
          MX\Configuration\WinFileCache-*.dat
          (these folders are normally hidden - you may have to use Explorer > Tools >
          Folder Options to unhide them)
          and delete it.
          Restart DW. Works better?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "Roger_D_T" <webforumsuser@macromedia.com> wrote in message
          news:e3qhfs$jhr$1@forums.macromedia.com...
          > error
          > message:
          > pop-up
          > control
          > TIA,
          > Roger
