4 Replies Latest reply on Jun 11, 2015 10:14 PM by rdsm
    Publishing Smart Preview Catalogs to an online file Repository
    rdsm
      I am developing a lightroom plugin in lua which will allow me to upload/publish smart preview catalogs to an online file repository.
      So far I have been successful in uploading jpegs to the online repository.
      However, now I am facing difficulty in building the smart preview files.
      local cat
      LrTasks.startAsyncTaskWithoutErrorHandler ( function ()
          cat = catalog:buildSmartPreviews(photos)
      end,'randomName')
      The LrCatalog object that the below code snippet is returning has nil data type value when I am trying to display the output using LrDialogs.message() function.
        • 1. Re: Publishing Smart Preview Catalogs to an online file Repository
          johnrellis Most Valuable Participant
          In your code snippet, the return value for catalog:buildSmartPreviews() is a table, not an LrCatalog object.  See the documentation for catalog:buildingSmartPreviews ():
          (table of arrays) A table with sub-arrays indicating the result of the smart preview build attempt. The sub-arrays are 'created', 'existed', and 'failed', and they contain LrPhoto objects corresponding to the photos for which the indicated status is appropriate.
          Also, if the code looks like this:
          local cat
          LrTasks.startAsyncTaskWithoutErrorHandler (function ()
              cat = catalog:buildSmartPreviews (photos)
               end, 'randomName')
          LrDialogs.message (...cat...)
          Then the value of "cat" in line 5 may or may not have been assigned on line 3.  The task started on line 2 is an asynchronous thread that may not have even started execution when line 5 is reached.
          The SDK requires that many of its calls must be executed in tasks other than the main task.  One common technique is to run your entire plugin in a task, so that you don't have to worry (as much) about this requirement.;
          • 2. Re: Publishing Smart Preview Catalogs to an online file Repository
            rdsm Level 1
            Hi johnrellis,
            Thank you for your reply. You are correct, I believe that the message is popping up as soon as i click on publish and after that the asynchronous thread is getting executed.
            I wish to first store the LrPhoto object (which is I assume is the Smart Preview Catalog) in a variable and then upload it to the repository. It is given that the function
            can only be called from within an async function. How do I go about ensuring that i first recieve the value of the variable and then publish it
            • 3. Re: Publishing Smart Preview Catalogs to an online file Repository
              Run your entire plugin code within a task:
              local function main ()
                  ...all the work of your plugin...
                end
              LrTasks.startAsyncTask (main, "main")
              Then this code within main() should work:
              local result = catalog:buildSmartPreviews (photos)
              ...access the contents of 'result'...
              • 4. Re: Publishing Smart Preview Catalogs to an online file Repository
                rdsm Level 1
                Hi John,
                Thanks for helping me out..
                Putting the function
                exportServiceProvider.processRenderedPhotos( functionContext, exportContext )
                within the main function does not execute it.
                Also, its throwing an error when i put main inside processRenderedPhotos function.
                For the moment, I have used LrTasks.sleep() but I would have to change it during testing.
                Also,
                local photos = {}
                for i, rendition in exportContext:renditions { stopIfCanceled = true } do
                   local photo = rendition.photo
                   LrTasks.startAsyncTask(function ()
                   LrDialogs.message(type(photo:buildSmartPreview()),photo:buildSmartPreview(),"")
                   end)
                   LrTasks.sleep(3)
                   photo:deleteSmartPreview()
                   table.insert(photos, photo)
                end
                local catalog = exportSession.catalog
                local result=  {}
                local pic
                   result = catalog:buildSmartPreviews( photos )
                   for key,value in pairs(result.created) do
                       LrDialogs.message("key number of result.created "..key,"type of value of result.created "..type(value),"Info")
                       pic = value
                       local picName = pic:getFormattedMetadata(fileName)
                       local picLocation = pic:getFormattedMetadata(filePath)
                       LrDialogs.message(picName,picLocation,"")
                   end
                end)
                LrTasks.sleep(3)
                I guess the following is happening:-
                result = { "created" = { {} , {} .........} , "existed" = { {} , {} .........} , "failed" = { {} , {} .........} }
                the number of keys of result.created is coming correct but all of them have nil values.
