1 Reply Latest reply on Jun 10, 2015 9:02 AM by A.T. Romano
    Premiere elements 8.0 unter Windows 8.1
    soprovideo
      Erstellung eines neuen Projekts nicht möglich. Bei Aufruf des noch leeren Neuprojekts Meldung: Projekt erstellt mit premiere pro kann nicht mit premiere elements geöffnet werden. hatte nie Premiere pro.
      Update von premiere elemnts 8.0 auf 8.0.1 erfolgte nach neuinstallation auf windows 8.1
        • 1. Re: Premiere elements 8.0 unter Windows 8.1
          A.T. Romano Level 7
          soprovideo
          I have found that Premiere Elements 8 will install and run on Windows 8.1 64 bit without issue.
          After you installed Premiere Elements 8
          a. did you disable the automatic Background Rendering and AutoAnalzyer features....
          (See Premiere Elements Editor workspace Edit Menu/Preferences/General for Background Rendering option; see Elements Organizer workspace, Edit Menu/Preferences/AutoAnalzyer Options for AutoAnalyzer Options).
          b. did you install the 8.01. Update from
          Adobe - Premiere Elements : For Windows : Adobe Premiere Elements 8.0.1 update
          Please verify...are you saying that, when you go to use Premiere Elements 8.0/8.0.1, you are getting a pop up message
          project created using premiere pro cannot open element with premiere
          1. From where are you getting your installation files?
          2. Delete the Adobe Premiere Elements Pref file, and, if that does not work, delete the whole 8.0 Folder in which it exists
          Local Disk C
          Users
          Owner
          AppData
          Roaming
          Adobe
          Premiere Elements
          8.0
          and, in the 8.0 Folder, is the Adobe Premiere Elements Prefs file that you delete. And, if that does not work, then you delete the whole 8.0 Folder in which it exists. Be sure to be working with Folder Option Show Hidden Files, Folders, and Drives enabled so that you can see the whole path given.
          3. If the above does not work, then do the following provided you have the purchased serial number and installation files or disc...
          a. Uninstall
          b. Free ccleaner run through (regular and registry cleaner parts) to get rid of leftovers from incomplete uninstalls reinstalls of Adobe and non Adobe products
          c. Reinstall with antivirus and firewall(s) disabled
          d. After 8.0 is installed, download and install the 8.0.1 Update.
          e. Make sure Background Rendering and AutoAnalzyer Options are turned Off.
          Please review and consider. We will decide what next based on your results.
          Thank you.
          ATR
