1 Reply Latest reply on Jun 10, 2015 2:15 PM by Reed Powell
    AXIS error using _setProperty()
    Reed Powell Level 3
      I'm moving an old app from CF8 to CF10 (Standard, 10,0,16,293499).  Pretty smooth transition except for one specific page that calls a webservice on our .NET webserver.  The CF8 app runs fine, here is the code snippet:
      <cfscript>
      WSoptions = {};
      WSoptions["username"] = "xxx";
      WSoptions["password"] = "xxx";
      ws = CreateObject("webservice", "http://hqimpetl01/searchAPI/toExcel.asmx?WSDL", WSoptions);
      blah blah blah blah
      </cfscript>
      The reason for setting the timeout is that some calls to the webservice can result in manipulating a lot of data.
      When I run it on CF10, I get this error:
      Web service operation _setProperty with parameters {axis.connection.timeout,30000} cannot be found.
      If I comment out that line, things work for the small files I test with, but sooner or later a user is going to give it something that needs time to run.
      I did some Googling, but ended up over my head in Java solutions.  Has anyone encountered this, and come up with a solution that can be implemented in CF?
      thanks
      reed
