I've got a piece of old Flash content that works fine when I drag it into a pod, but every student is running their own instance of the swf. I'd like to be able to synch some of the actions so that the changes on one student's screen shows on everyone else's. Which my developer tells me needs the 'Collaboration Builder SDK'. Two things, though. The current version of the SDK is written for Flex, and not Flash, and my developer only works in Flash. Also, the code in the swf is Actionscript 2, which is what (I'm told) the Collaboration Builder SDK version 7 is written for. So, are you able to supply a link (Adobe support) / share a copy (forums) (the SDK is free) of Collaboration Builder SDK version 7 so I can enhance the swf I currently use, without having to have the whole thing rewritten from the ground up? I realise that this is 2 gens 'old' and won't be supported now, so if what I'm trying to do doesn't work, I won't be moaning about it! Many thanks, David
Your best bet is to reach out to Adobe Support and see if they have it laying around and can brush the cobbwebs off to share it with you. Adobe Connect Help | Adobe Connect Support
If I recall correctly, the SDK has always been for Flex though, so the SDK for Connect 7 and older may require an older version of Flex (2.5?).
Thank you Jorma, I will pass on your advice, and am trying to get Adobe to find the link to the old SDK. Thanks again!
