9 Replies Latest reply on Jun 11, 2015 12:16 PM by JohnnyBQue
    Educate me...There is some section of code that I'm not sure as to what it reperesents...
    JohnnyBQue
      Being new to java-script and learning on the fly at time I try to get things straight in my mine...In doing so I end up using code that have segments that I don't under stand. Below is a section of code that comes from a dynamic stamp. The words that I've highlighted in RED are what I'm needing to be explain to me as to; what they pertain to in the stamp itself; The whole code is at the bottom of the page if you need to reference it.
      Thanks guys....
             if(event.source.forReal && (event.source.stampName == "#fF_WBqLLUm0cA33ryprG3A"))
                if ("ok" == app.execDialog(dialog)) <<<<< I understand what this is
                var cMsg = dialog.starValue; <<<<< I understand what this is
                event.value = "\n" + cMsg; <<<<<<< I believe I know what this does....anything typed within "\n" will also show up in the text field plus dialog starValue
                event.source.source.info.mj = cMsg; <<<<<I'm not sure what this does and I don't know what "mj" represent. What suppose to come after ".info._ _ _"
                cMsg = "\n" + dialog.mjValue;<<<<< I understand what this is
                this.getField("MJ/m²").value = cMsg; <<<<<<does the :getField mean the text box from the stamp? and is "MJ/m2" the name of the text box in the stamp?
                cMsg = "\n" + dialog.accValue;<<<<< I understand what this is
                this.getField("accreditation").value = cMsg; <<<<< As with "MJ/m2" I'm not sure what "accreditation" represents here.
      WHOLE CODE
      var dialog = {
      starValue: "",
      mjValue: "",
      accValue: "",
      bChk1:false,
      bChk2:false,
      initialize: function(dialog)
           var dlgInit =
           "Chk1": this.bChk1,
           "Chk2": this.bChk2,
            dialog.load(dlgInit);
               commit:function (dialog) { // called when OK pressed
                    var results = dialog.store();
                    this.starValue = results["txt1"];
                    this.mjValue = results["txt2"];
                    this.accValue = results["txt3"];
                    var oRslt = dialog.store();
                    this.bChk1 = oRslt["Chk1"];
                    this.bChk2 = oRslt["Chk2"];
                     description:
                               name: "Energy Rating Information", // Dialog box title
                              elements:
                            type: "view",
                            elements:
                                           name: "Enter Star Rating: ",
                                                   type: "static_text",
                                           item_id: "txt1",
                                           type: "edit_text",
                                           multiline: true,
                                           width: 300,
                                           height: 20
                                           name: "Enter MJ/m²: ",
                                           item_id: "txt2",
                                           type: "edit_text",
                                           multiline: true,
                                           width: 300,
                                           height: 20
                                           name: "Enter Accreditation Number: ",
                                           item_id: "txt3",
                                           type: "edit_text",
                                           multiline: true,
                                           width: 300,
                                           height: 20
                                           type: "view",
                                           char_height: 10,
                                           elements:
                                           item_id: "stat",
                                           name: "What type of rating is this?:",
                                           char_width: 15,
                                           alignment: "align_fill",
                                           font: "dialog",
                                           type: "view",
                                           char_width: 8,
                                           char_height: 8,
                                           align_children: "align_top",
                                           elements:
                                           type: "view",
                                           char_width: 8,
                                           char_height: 8,
                                           elements:
                                           type: "check_box",
                                           item_id: "Chk1",
                                           name: "Single dwelling",
                                           type: "check_box",
                                           item_id: "Chk2",
                                           name: "Multi-unit development",
                                            type: "ok_cancel",
                                            ok_name: "Ok",
                                            cancel_name: "Cancel"
