0 Replies Latest reply on Jun 11, 2015 11:38 AM by krunalm83439908
    signed RSL being fetched instead of unsigned RSL
    krunalm83439908
      I have added unsigned RSL ("framework_4.1.0.21490.swF") as primary RSL in flex-config.xml But, when the main player swf is loaded, it ends up fetching framework_4.1.0.21490.swZ file from adobe site.
      Suprisingly I've other unsigned RSLs added (textlayout, osmf, spark, ...) which always go to the local path (hosted unsigned RSLs).
      Am I missing something ? (For my case I want to fetch unsigned RSL first. If that one fails ONLY then I want to go to signed RSL)
      flex-config.xml snippet:
      <runtime-shared-library-path>
      <path-element>libs/framework.swc</path-element>
      <rsl-url>framework_4.1.0.21490.swf</rsl-url>
      <policy-file-url></policy-file-url>
      <rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.1.0.16076/framework_4.1.0.21490.swz</rsl-url>
      <policy-file-url>http://fpdownload.adobe.com/pub/swz/crossdomain.xml</policy-file-url>
      </runtime-shared-library-path>
      mxmlc command:
      $ mxmlc.exe -define+=CONFIG::LayoutDirection,'ltr' -optimize=true -static-link-runtime-shared-libraries=false +flexlib flex_sdk_4.1\frameworks -debug=false -benchmark=true -source-path src\ -file-specs src\Player.mxml -compiler.library-path flash\ flex_sdk_4.1\frameworks\libs flex_sdk_4.1\frameworks\locale\en_us -compiler.include-libraries ..\shared\bin\shared.swc ..\core\bin\core.swc -compiler.external-library-path+=flex_sdk_4.1\frameworks\libs\framework.swc  -output .\bin\Player.swf
